Roof function for control signals?
Page 1 of 1 [6 Posts]
torsig1967
PostPosted: Mon Sep 29, 2008 11:17 am    Post subject:  Roof function for control signals?
Subject description: Can I implement this in a cheap way
I'm looking for some way to make a roof functions for control signals.
Working something like this.
input: 0-32 --> output: 0-32 (1:1 ratio)
input: 32-64 --> output: 32 (always 32)
I've figured out a way to (almost) do it with NoteVelScal but it's to CPU expensive for my need and seems to me there's no cheaper way.
But I might be wrong.... Confused
Audio files: 297
PostPosted: Mon Sep 29, 2008 11:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Some ideas, non tested.
How about using a cross fader, one input left unconnected the other connected to a constant setting the limit. Then use the fade control input as the input and multiply it by a constant as needed.
For your example the amplification would be two and the limit as set with the constant module would be 32.
Or another way to go could be to use the clip module, set it to work asymetric (its default) and add (or subtract) a value as needed from your input signal that you then subtract (or add) again at the output.
Or maybe easiest ... use cross fader and a compare module, when the input is under the threshold pass trough the input signal and when it's over the threshold switch to a constant value. The constant could be used here as the input for a A>=B comparator and as the input for the cross fader at the same time I think, so just three cheap modules needed.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Sep 29, 2008 9:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, don't slam the Nord into my face yet, but I just want to know what a 'roof function' is and what you want to do with it Smile Maybe it's just a configuration in which all values from 0 up to 32 can be used and all values above 32 will stay 32? Kind of a blue limiter...?
Wout
torsig1967
PostPosted: Tue Sep 30, 2008 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout
Not sure if "roof function" is the correct term, but mathematically speaking:
f(x) = x , 0<x<32>32
torsig1967
PostPosted: Tue Sep 30, 2008 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
[quote="torsig1967"]
Wout
f(x) = x , x = [0, 32]
f(x) = 32 , x = [32, 64]
torsig1967
PostPosted: Tue Sep 30, 2008 2:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, this is the best I can do right now.
Input value goes from -64 to 64 while output varies like this:
Input -64 to 0 -> output 0-64
Input 0 to 64 -> output 64
Mathematically:
f(x) = x + 64 , x = [-64, 0]
f(x) = 64 , x = [0, 64]
1% CPU I think.
I'd love to get rid of the diode module to get much less CPU but I can't think of how to replace that with something cheaper....
PS. To modify this for the intervals I was asking for earlier (0-32,32-64) I don't think shoould be too hard. But I don't need that right now so I didn't investigate this. DS.
This implements a roof curve (defined earlier in this thread) but with a slightly different input interval. Here the roof curve output goes to a amplifier for testing.
 Filesize:  80.93 KB
 Viewed:  3682 Time(s)
