jonkull
Joined: Sep 22, 2006 Posts: 164 Location: Burbank, CA
Posted: Wed Oct 01, 2008 12:42 pm Post subject:
Anyone using Andromeda MixMaker with Parallels on a Mac? |
Anyone using this? I can't seem to get it to work. It always crashes on launch. |
Mark-io
Posted: Wed Oct 01, 2008 3:25 pm Post subject:
it probably cant detect any midi I/O ports. does it create a file called "banker.ini" in its program folder? _________________ author of the Andromeda Banker and Mix Maker utilities. |
jonkull
Posted: Wed Oct 01, 2008 7:07 pm Post subject:
Doesn't look like it. I'm going to reinstall my midi drivers and try again. Hey I had emailed you a few weeks ago but didn't get a reply (or it went to my spam filter)...are you still working on a sequencer programmer for the A6?
Thanks. |
Mark-io
Posted: Thu Oct 02, 2008 10:46 am Post subject:
Quote: | Hey I had emailed you a few weeks ago but didn't get a reply (or it went to my spam filter)...are you still working on a sequencer programmer for the A6? |
i did send a reply but my provider is often blacklsited ( because its an open relay server )
anyway... yes, still working on a Sequence editor but i havent got any spare time at the moment due to job demands & pressing family matters.
plus i ran into a few problems with the A6 firmware and have to rethink a bit or find workarounds... ill keep this forum posted if there's any progress but plz dont hold yr breath _________________ author of the Andromeda Banker and Mix Maker utilities. |
jonkull
Posted: Thu Oct 02, 2008 11:20 am Post subject:
I understand. I've been busy with the same (work and family) and lucky to get half an hour here and there just to turn the A6 on. Thanks for the info. |
Jyoti
Posted: Thu Oct 02, 2008 4:53 pm Post subject:
Interesting info, thank you! _________________ My music: here! |
MarkShovel
Joined: Oct 21, 2008 Posts: 1 Location: United States
Posted: Tue Oct 21, 2008 8:02 am Post subject:
Banker and MixMaker |
Hi Mark-io,
I have been using the trial version of your programs the past few days. I'm using a Windows PC and a midiman 2x2 interface.
I can transfer single programs. However full bank transfers fail. I have adjusted the delay and buffer sizes without any improvement. The A6 display shows that the data transfer is continuing, the midi interface LEDs also show the data continues, but Banker stops receiving data after 2 to 12 programs.
The MixMaker also fails to get all of the data to start any activity. So the problem seems common with both applications.
Thank you for generating the programs. I hope to get a functional system and will pay you for your code development.
Mark |
