Lofi Ninja
Posted: Sat Jul 11, 2009 2:37 pm Post subject:
Back again. My ECC81 tubes went missing. I found an old, bashed tube radio today. I salvaged the tubes, and among them where two ECH81's and an EL84 aswell. Can they be used for this ? I know the ech81 are heptodes but I'm pretty sure I read something about using them as oscillators in old radios or something.
Oh and there also was an EM80 tuning indicator tube.. Do you got some cute little pre-amp I can slap that on ? _________________ www.youtube.com/user/lofininja |
frequencycentral
Posted: Sun Jul 12, 2009 4:23 am Post subject:
| Lofi Ninja wrote: | Back again. My ECC81 tubes went missing. I found an old, bashed tube radio today. I salvaged the tubes, and among them where two ECH81's and an EL84 aswell. Can they be used for this ? I know the ech81 are heptodes but I'm pretty sure I read something about using them as oscillators in old radios or something.
Oh and there also was an EM80 tuning indicator tube.. Do you got some cute little pre-amp I can slap that on ? |
Nice to know this thread still lives in some peoples minds!
Hmm, dunno, never used heptodes, they sure do look weird on the data sheet though. The EL84 would make the basis of a nice little amp. As for pre amp, search my posts over at http://www.diystompboxes.com/smfforum/forums.html?board=2.0 _________________ http://www.frequencycentral.co.uk/ |
marmora
Posted: Mon Jan 18, 2010 1:18 pm Post subject:
Finished my Crushed Glass today!
Sounds great...well, it sounds great if you like noise! It's loud, it's nasty - I love it! Fans of the Atari Punk Console or similar designs will not be disappointed.
I changed the value of C4 to .1uf. I just wasn't hearing enough change with the original value. With each frequency control all the way down, the sound cuts out. Good for a quick on/off control, or so that you can hear one oscillator at a time.
I'm running it at 12v, but I tried 9v to see how it would sound and it works - the tubes just aren't coming to life the same way and the volume is lower.
This would be a great building block for a tube synth or for noise makers.
Here's the layout I used:
http://www.aronnelson.com/gallery/main.php/v/marmora/crushed+glass.jpg.html
I used an IC to show where the tube goes. Pin 1 of the IC is pin 1 of the tube etc.
Thanks Rick (frequencycentral)! |
Spotta
Posted: Tue Jul 24, 2012 6:10 am Post subject:
Hi
I have just built this following marmora's stripboard diagram and although both valves are glowing I'm only getting sound on the last third of travel of P1 and P2 has no effect at all.
Are there some voltages I can take from various places that would tell me if I have a dodgy valve? _________________ --
Spotta |
-minus-
Posted: Tue Nov 27, 2012 2:07 am Post subject:
Did you get yours working spotta?
My tubes were sitting in the mailbox all day! About to start breadboarding. Will report findings here shortly. Using 6111's... |
Spotta
-minus-
Posted: Tue Nov 27, 2012 6:01 am Post subject:
Excellent! I was giggling like a madman all the way through your video . Noisy little buggers aren't they? I just got mine fired up on breadboard and cranked it at full volume through a bass amp...at midnight! I think I disturbed a few people.
There will now be a short intermission followed by another test at 1AM through a ring modulator.
I'm going to try a few changes with the frequency caps and see what happens. I think part of this things charm is that difference between the high pitched hiss and the low frequency thud. I noticed your pots work like mine do... which seems to be reverse to what I'd consider normal. Clockwise appears to lower the frequency here. I may change it around.
Overall though a fun circuit!  |
Spotta
Posted: Tue Nov 27, 2012 7:04 am Post subject:
Yep, I have a few mods to make, too busy making other euro rack projects at the mo. I do intend to make a module out of it in the end  _________________ --
Spotta |
frequencycentral
-minus-
Posted: Wed Nov 28, 2012 1:12 am Post subject:
I've been fiddling with this a bit today, changing capacitor values etc. One thing I've been unable to do with this is ring modulation.
I've tried feeding each of the two oscillators into the inputs but had no luck. Then I fed both oscillators into the one input and a carrier signal into the other. That didn't work either. I started to think there was something wrong with the ring modulator but it checks out fine with other oscillators. I'm wondering if the output is just too f****d up (for want of a better word) to work. Any one else get this working? I'm going to get hold of some germanium diodes and try a different ring modulator design but I suspect I won't have much joy.
Still, it is a great device. There is nothing quite like it for making extreme noise.  |
Draal
Joined: May 18, 2010 Posts: 284 Location: Oak Park, IL
Posted: Fri Dec 14, 2012 12:14 pm Post subject:
I've been wanting to build the crushed glass for a while; hopefully I'll get some time to mess around with some 12AX7's with it. Got an old tiny chassis from a tube record player with blown power transformer sitting around.
Time will tell... _________________ Zontar Prevails! |
LFLab
Joined: Dec 17, 2009 Posts: 142 Location: Rosmalen, Netherlands
Posted: Sun Dec 16, 2012 6:51 am Post subject:
| Any chance on adding voltage control to these? |
frequencycentral
Posted: Sun Dec 16, 2012 7:11 am Post subject:
| LFLab wrote: | | Any chance on adding voltage control to these? |
You should be able to add a vacrol in the feedback loop. Or you could try installing a cathode resistor and bypass cap, then pump CV into the cathode. It's NEVER gonna be 1V/oct though! _________________ http://www.frequencycentral.co.uk/ |
LFLab
Posted: Mon Dec 17, 2012 2:41 am Post subject:
that makes sense Rick, thanks.
And since accuracy is not possible, might make sense to use two vactrols and some control circuitry to use the same voltage divider that there's in there now. Of course four are needed since there's two oscs.
Might need to order some extras of the cheapie cheapie kind (single unmatched Silonex NSL32)
Jarno. |
Taylor
Posted: Mon Dec 17, 2012 10:00 am Post subject:
In my build, there is a relatively small sweet spot within each pot that really houses interesting sounds, and they are very interactive with each other. So, to me, voltage control might not make a ton of sense as you really need an intelligent agent tuning the controls to get interesting sounds.
If you've built it and want VC, please don't let me stop you. But I'd recommend breadboarding the circuit first to get a feel for it before you start modding, if you haven't already. Just my two cents.  _________________ musicpcb.com |
frequencycentral
Posted: Mon Dec 17, 2012 10:34 am Post subject:
The sweet spot could be expanded to the entire range of the pots by putting a resistor in series either side. _________________ http://www.frequencycentral.co.uk/ |
Taylor
Posted: Mon Dec 17, 2012 4:07 pm Post subject:
| frequencycentral wrote: | | The sweet spot could be expanded to the entire range of the pots by putting a resistor in series either side. |
Truedat, I played around with this but for some reason didn't get satisfactory results because of the interactivity. Some sounds out of one oscillator could only be had when the other's pot is out of "useful" range.
In any case, I have a lot of fun with this and I use it as the main noise source in my modular. I even brought the tubes out onto the front panel in flamboyant fashion. Pictures soon. _________________ musicpcb.com |
slacker
Posted: Tue Dec 18, 2012 1:55 pm Post subject:
| You could maybe add fine adjustment pots, stick say 1k to 10k pots wired as variable resistors between the bottom of the existing pots and ground. This would let you dial in roughly the sweet spot on the original pot and then use the fine pot for greater control. |
