how to modulate the master volume?
Page 1 of 1 [6 Posts]
mr.extrem
Guest
PostPosted: Tue Oct 07, 2008 4:50 pm    Post subject: how to modulate the master volume? Reply with quote  Mark this post and the followings unread
How do you make a simple modulation of the output level with the andromeda? A simple tremolo Effekt ???
Because there is only "Pan Modulation" on the output section available, but no level modulation.
How do you do this?
rh2y
PostPosted: Wed Oct 08, 2008 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
There is no "modulate the master volume", but you can acheieve a tremolo effect by modulating the VCA level. I'm not sitting in front of my A6 right now, but I believe you need to set up a custom modulation routing, and have (for example) the LFO modulate the VCA level.
Otherwise, you might want to try using a Lezlie effect in the digital effects section, as well.
Hope that helps,
Russ
Shameless plug: http://www.soundcloud.com/rh2y
Shameless-er plug: http://www.evatontechnologies.com/
Music: https://atomstomolecules.bandcamp.com/releases
mr.extrem
Guest
PostPosted: Wed Oct 08, 2008 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
which vca do you mean. post filter mix level?
rh2y
PostPosted: Wed Oct 08, 2008 9:38 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you may need to modulate several of the "mix" levels at the same time, depending on which elements of the filter you are using. But, yes, the mix levels are what you want; I'm pretty sure. Like I said, I'm at work right now and not in front of my A6, so I may be a little off on that.
Russ
mr.extrem
Guest
I think i have finally found a good way to modulate the master volume.
You can modulate the level of the amp envellope. So this way you have controll of the master volume..
elmacaco
PostPosted: Thu Oct 09, 2008 6:56 am    Post subject: Reply with quote  Mark this post and the followings unread
LFO mod of the amp envelope is a default setting on the default patch. I think it's mod button one.
might be interesting to mod the pre/post mixer levels though.
