Audent
Posted: Tue Oct 28, 2008 7:39 pm Post subject:
EFM VCF-6C EMS Diode Ladder Filter info??? |
I don't know where else to ask this...
I was recently given an unpopulated EMF VCF-6C PCB from a friend....I'd love to put it together, but I'm having a hard time finding a parts list. Most of the components are obvious from the schematic, but some of the capacitor types are a bit fuzzy as well as the trannys
can anyone help me out on this? |
machine.cuisine
Posted: Sat Nov 01, 2008 1:17 pm Post subject:
This is from an old print-out of the original EFM doc:
- Resistors -
1-3, 12 are 47k
3(?), 5, 18, 20 are 1k
6 is 2.2k
7, 9, 13, 19, 24 are 10k
8 is 470k
10, 14-17 are 100k
11 is 220 ohm
21, 22 are 220k
23 is 1M
All pots and trimmers are 50k
- Caps -
1, 2, 4-7 are 0.1uF
3, 9, 10 are 10uF/16V
8 is 220uF/16V
- IC/Transistors -
Q1, 2, 4 are 2N3904
Q3, 5 are 2N3906
U1 is a LM13600
The diode array calls for the expensive MAD1108 - although regular (preferably matched) 1N4148's or even LED's can be used.
I hope this helps. Also see http://www.modular.fonik.de/Page37.html and check the "forum" notes for mods, etc for this and other EFM modules.
Audent
Posted: Sun Nov 02, 2008 8:58 am Post subject:
Cool! Thank you! |
Tim Stinchcombe
Joined: Dec 07, 2008 Posts: 26 Location: Cheltenham, Glos, UK
Posted: Mon Dec 08, 2008 7:22 am Post subject:
Hi Audent,
[First post to electro-music - well you have to start somewhere!]. No idea if you will still pick this up, but hopefully so, as the thread isn't that old - I forwarded the pdf of this filter to fonik a few days ago, and he has immediately put it up on his site, at the link given above.
Tim |
Audent
Posted: Mon Dec 08, 2008 1:27 pm Post subject:
| Tim Stinchcombe wrote: | Hi Audent,
Tim |
Killer! Thanks- that helps a lot. These are seriously the most helpful forums out there.  |
