ChrisSousa9
Joined: Nov 29, 2008 Posts: 14 Location: North Carolina
Posted: Mon Dec 01, 2008 7:40 pm Post subject:
Using a Stripboard as a Final Product |
So, I recently got started into making my own schematics and such on breadboards (About a year ago). So I know they're are about three ways you can make a circuit 1) Breadboard 2) Stripboard 3) PCB. I've always used pre-made PCB whenever I build a circuit, quiet cost consuming if I don't say myself (No offense to any Synth PCBer's, Ray Wilson has awesome PCB's). But I thought about just using stripboard for my synth projects and solder my leads on the bottom. The good thing about this is a save about $20 for buying or designing my own PCB. Of course you run definetly have a lot more on the board itself, And that could lead to some design flaws. Im want to know some of your opinions on this. Is it safe with building Power Supplies on? _________________ www.soundabstract.net
"Overprotecting intellectual property is as harmful as underprotecting it. Culture is impossible without a rich public domain. Nothing today, likely nothing since we tamed fire, is genuinely new: Culture, like science and technology, grows by accretion, each new creator building on the works of those who came before. Overprotection stifles the very creative forces it's supposed to nurture." - Alex Kozinski, Ninth Circuit Federal Court of Appeals Judge |
DrJustice
Joined: Sep 13, 2004 Posts: 2005 Location: Morokulien
Posted: Tue Dec 02, 2008 7:34 am Post subject:
The thing with stripboards is that big projects can become a bit messy and not so fun to maintain or repair. Other than that I see no reason not to use them if it suits you. High speed digital circuits may emit more noise, and some critical analogue circuits may not perform as well, as on a purpose designed PCB with optimal ruoting, ground and power planes etc.. Most synth related circuits should be fine, though. You can safely use stripboards for power supplies too, as long as you are careful with the construction and not too much heat is generated.
DJ
kxspxr
Posted: Fri Dec 05, 2008 3:24 am Post subject:
I have succesfully used veroboard/stripboard on all my DIY projects. Ring modulators, LFO, VCO, VCF and ELF radios. Everything still works to perfection. The drawback is that it can be quite messy and difficult to repair, as DrJustice noted. On the other hand, it's quick and dirty compared to PCB-making, hole drilling etc. I have considered on several occasions to start making PCB using the phototransfer method. It looks easy and I might just look into that between xmas and new year since I have a friend who offered to help me get startet. If I were you I would look into the phototransfer method too... and use stripboard for smaller projects.
I found a straight forward tutorial for phototransfer here:
http://www.youtube.com/watch?v=QQupRXEqOz4
EDIT: You can also consider getting Futurlec to make the PCB's for you. It's actually quite cheap: http://www.futurlec.com/PCBService.shtml
-kasper _________________ "Posthumanity is a discrete set of processes with arbitrary return codes." |
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Fri Dec 05, 2008 3:53 am Post subject:
I've used stripboard for many projects and they all work just fine. The messiness aspect can be fixed by laying out designs using a layout application like Lochmaster. It makes it easy to design layouts which are compact, noise free, easy to work on, etc. I've used stripboard to build PSUs (like my latest one) and plan on doing a beefed up version which deliver 3Amps per rail. It mostly comes down to using the same kind of design principles which you use in PCB layouts. Plenty of space for hot parts, offboard connections where they are appropriate, sufficient traces for high current etc.
If you don't see the stripboard layout as a "temporary", "make shift", or "rough version" etc. it won't be.
Include proper insulated mounting holes. Mark your cuts with a felt pen before cutting them. Maximise the length of traces connected to Ground and minimise all others.
Use PCB "pins" with heatshrink for off board connections, or .1"molex connectors, or .2" screw down terminals. Count your wire links, and count them again,........ and again.
Any issues with noise immunity can be fixed with small brass sheet "Faraday cages" in a way which is actually better than most PCBs. It would be pretty rare though. _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
picsynth
Posted: Mon Dec 08, 2008 6:59 pm Post subject:
I use stripboard for everything, including a replacement 24v 2amp power supply for my oscilloscope !
In PICSynth all of the boards are stripboards. You can get quite fast at doing layouts using math paper...and pencil.
The only exception I can see is if you are working at high frequencies eg Radio RF work and the capacitances between the tracks become important.
Not a porblem at Synth frequencies.
I don't bother making PC boards, I am usually pulling apart and remaking far to often for that
Kevin
http://www.geocities.com/picsynth |
kxspxr
Posted: Tue Dec 09, 2008 2:24 am Post subject:
You can download DIY Layout Creator and use it on any computer that supports Java. You can use it to layout stripboards before soldering. Oh, and it's free
Linux/OSX/Win:
http://www.storm-software.co.yu/diy/forums.html?project=software _________________ "Posthumanity is a discrete set of processes with arbitrary return codes." |
MrUmunhum
Joined: Apr 05, 2009 Posts: 4 Location: Mt Umunhum, CA
Posted: Sun Apr 05, 2009 4:55 pm Post subject:
Dead link |
This is a dead link. Do you have a current one for Linux? |
kxspxr
Posted: Mon Apr 06, 2009 2:34 am Post subject:
Re: Dead link |
No sorry. This was the place I found it. I have DIY Layout Creator (multiplatform version) since I use mac, so if your box runs java I can upload the software to my ftp (yes I saved a copy) and post the link here.
Tell me if you're interested.
aerogramma
Joined: Feb 27, 2008 Posts: 148 Location: Roma, Italy - London, UK
Posted: Mon Apr 06, 2009 8:01 am Post subject:
I would be too
thanks!
aero |
MrUmunhum
Posted: Mon Apr 06, 2009 11:05 am Post subject:
Re: Dead link |
| kxspxr wrote: |
-kasper |
Yes please, I have been trying for days to find it. It happers that the site has lost its Domain Name? |
slacker
MrUmunhum
Posted: Tue Apr 07, 2009 9:04 am Post subject:
Got it to run but! |
OK, downloaded it unzipped it and ran under Java. It comes up but page is blank and no library routines ( library window is blank ).
Do I need to start it with some options? Is there a tutorial somewhere? The help references the old web site.
Sorry to be a pain. This looks like to best fic for my needs. |
kxspxr
Posted: Wed Apr 08, 2009 4:50 pm Post subject:
Re: Got it to run but! |
| MrUmunhum wrote: | OK, downloaded it unzipped it and ran under Java. It comes up but page is blank and no library routines ( library window is blank ).
Sorry for the delay in my reply ... been soldering my pants off the past 2 weeks.
DIY Layout Creator Beta with Library --->
http://www.perlepladesyndikatet.org/temp/diylc_beta.zip
MrUmunhum
Posted: Fri Apr 10, 2009 8:58 am Post subject:
I quit! |
| kxspxr wrote: | | MrUmunhum wrote: | OK, downloaded it unzipped it and ran under Java. It comes up but page is blank and no library routines ( library window is blank ).
Sorry to be a pain. This looks like to best fit for my needs. |
-kasper | Kasper,
Thanks for all of your help but I can't get it to work. I downloaded the last zip file, unzip it and ran 'java -jar DIYLC.jar' and it just when into a loop. This is the output:
$ java -jar DIYLC.jar
Component [Blank Board] successfully loaded from the file /src/DIY_Layout/PBL2/diylc_beta/library/blank-board.xml
Component [Capacitor (Axial)] successfully loaded from the file /src/DIY_Layout/PBL2/diylc_beta/library/capacitor-axial.xml
Component [Capacitor (Ceramic)] successfully loaded from the file /src/DIY_Layout/PBL2/diylc_beta/library/capacitor-ceramic.xml
Killed
I quit. Thanks again and sorry to take up your time. |
Sine
Joined: Sep 10, 2007 Posts: 111 Location: Netherlands
Posted: Fri Apr 24, 2009 4:40 pm Post subject:
Re: I quit! |
I use matrixboard for about everything I build ... except for projects where reasonable priced boards are available. ( such as MOFS and CGS boards )
Building a circuit on strip/matrix board is VERY time consuming, if I can buy a board for a few bucks I will go for it.
Personally I don't use stripboard, its way too messy for me and compact building is virtually impossible, matrix board is a bit more work but I think it gets a much better result.
Try this on strip :
Posted: Sat Apr 25, 2009 5:56 pm Post subject:
in the electronotes bernie hutchins recommended just surface mounting the parts on an etched PCB, so no drilling is needed. does anybody use this method? i am just curious. _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
