  Paulo Santos Synth-ing NºX
Living VCOs
Page 3 of 21 [519 Posts]
Goto page: Previous 1, 2, 3, 4, 5, ..., 19, 20, 21 Next
Would you prefer one PCB with 3 VCOs a la JH-5A, or 1 VCO per PCB with more features
One PCB with Oscillator Driver and 3 VCO cores (like JH-5A - cheap!)
60%
 60%  [ 62 ]
1 PCB = 1 VCO (with many waveforms and inputs)
39%
 39%  [ 40 ]
Total Votes : 102
fluxmonkey
PostPosted: Sat Dec 13, 2008 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
frijitz wrote:
mono-poly wrote:
I'd love to see a Buchla 158 or 144 like vco.
Simple vco with 1 waveform output.
But great fm and/or am sound.
I proposed doing this several months ago, but there wasn't much interest:
http://electro-music.com/forum/topic-28713.html
I guess if it doesn't say M... or B..... it's gonna get killed by the fanatics.
Ian
ian, i expressed interest at the time, and it remains... i wouldn't have seen this as an either/or situation, and would certainly pick up both if they come to fruition.
if you're queueing up projects, tho, i'm really looking forward to the DoubleDeka, ahead of anything else you've proposed... that is gonna be tasty!
www.fluxmonkey.com
frijitz
Audio files: 54
PostPosted: Sat Dec 13, 2008 3:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think we should move any more discussion of this over to its own thread.
Thanks.
Ian
xpmtl
PostPosted: Sat Dec 13, 2008 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Funky40 wrote:
johans121 wrote:
As long as I have money to blow, you'll continue to receive it Wink
Laughing
i'm in the same boat
one more on the boat here
http://sdiy.xpmtl.net
ach_gott
PostPosted: Mon Dec 15, 2008 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
xpmtl wrote:
Funky40 wrote:
Laughing
Is there room for me on the boat? Smile
johans121
PostPosted: Tue Dec 16, 2008 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
the more the merrier Smile
Don't feed me Indian, you WILL regret it!
-Jim
alain6870
PostPosted: Tue Dec 16, 2008 2:04 pm    Post subject:
Subject description: Explaining the detune capacity in a few simple words
Hello Jürgen,
I think your design with 3 VCO on the same PCB is interesting for me. I would like to use it to create string pads or brass leads and for that purpose saw and square waves are ok. And if your design is based on a saw oscillator it would be easy to add as many waveshaper we want on extra pcbs. What really matters is the detune automation... If I don't misunderstood what you described, I could dare to summeries it this way: Embarassed
- linear detune (V/Hz) scale not influenced by the expo input (V/oct):
- 1 Hz detune between 2 oscillators (for instance 440 Hz and 881 Hz) stays 1Hz if I play an A5 (we have then respectively 880 Hz and 1761 Hz on both VCOs)
Best Regards
Alain
PS: Of course I would try one if your selling PCBs
jhaible
PostPosted: Tue Dec 16, 2008 2:12 pm    Post subject:
That will be one of its features indeed.
JH.
Now playing: Brian Eno, Music for Films
igormpc
PostPosted: Sat Jan 03, 2009 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
i am interested in one pcb also.
plord
PostPosted: Tue Jan 06, 2009 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am interested in at least one Smile
Electronicant
PostPosted: Tue Jan 20, 2009 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
The result of the poll point at the cheaper 3 VCO model with less waveforms. A suggestion for wave selection could be the stepless variable saw/pulse waveshaper used on MOTM-310 and Micromoog/Multimoog. Maybe that´s more complicated than the toggle on the JH5, but it´s the solution Moog choosed for their budget Micromoog. It´s a nice function and I assume that it could make the living VCO even more living Wink
Krelnarb
PostPosted: Wed Jan 21, 2009 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm also interested in at least one.
thanks!
synthetic
PostPosted: Fri Feb 13, 2009 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looking forward to two or three oscillators like this.
jhaible
PostPosted: Fri Feb 13, 2009 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's going to happen.
I've been working some hours on this today.
It will be 3 VCOs on one PCB.
I start with the core parts, and then see what else will fit on the board.
JH.
303monkey
PostPosted: Sun Feb 22, 2009 7:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I would be up for 1, if not 2
2thick4uni
PostPosted: Sun Feb 22, 2009 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Count me in for a pcb
aerogramma
PostPosted: Mon Feb 23, 2009 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
2 vco's on one pcb is ideal Juergen,but would be perfect if u just could add sine for both 2 on the pcb
I also vote for SINE out ... there're relatively few modules outtputting sinewaves Wink
thanks!
aero
synthetic
PostPosted: Mon Feb 23, 2009 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sweet!!! I've been waiting for this for a while.
jhaible
PostPosted: Mon Feb 23, 2009 2:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks!
aero
No sine waves - sorry.
There is only so much I can put on a single PCB, and I decided to put 3 VCO cores there, plus a discrete PWM circuit per VCO, just like the JH-5 has.
JH.
TekniK
PostPosted: Mon Feb 23, 2009 10:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks!
aero
I don't care abouth sines,but i need them for my wave multipliers
jhaible
PostPosted: Sat Feb 28, 2009 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a little preview of what I'm working on.
Looks like I can indeed put 3 VCOs plus an Oscillator Driver on a single board! This may get very close to the whole oscillator section of my JH-5, just on a single 160mm * 100mm PCB.
JH.
 Filesize:  241.72 KB
 Viewed:  301 Time(s)
 Filesize:  377.94 KB
 Viewed:  321 Time(s)
TekniK
PostPosted: Sat Feb 28, 2009 4:53 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
thumright
mono-poly
PostPosted: Sat Feb 28, 2009 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm somehow i am getting interested Very Happy
jhaible
PostPosted: Sat Feb 28, 2009 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Just finished PWM section of one channel.
PWM will be all discrete - no opamps in here!
Also, PWM works like in the CS-80: You can heavily overmodulate it without loosing the signal!
JH.
dingebre
PostPosted: Sun Mar 01, 2009 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, you don't waste time do you Smile Congratulations on the progress.
I will purchase two PCB sets at least regardless, but was wondering what tracking accuracy you were shooting for?
For outputs, there will be a PWM amd sawtooth as in the JH-5, right?
Thanks for your efforts and for sharing your skill and talent.
David
dingebre@3dphysics.net
jhaible
PostPosted: Sun Mar 01, 2009 2:31 am    Post subject: Reply with quote  Mark this post and the followings unread
David
Tracking: decent. Good enough for a mono synth. No efforts to get ultimate precision.
PWM and saw, yes.
JH.
