LM13700 1 volt/octave temperature stable VCO ?
Page 1 of 1 [11 Posts]
frequencycentral
PostPosted: Sun Dec 14, 2008 11:24 am    Post subject: LM13700 1 volt/octave temperature stable VCO ?
Subject description: Is there such a design floating around ?
I just love the LM13700!
I've used it for VCOs and VCLFOs in my mini sound effects synth where stability/tracking isnt an issue. I've also designed a tube tremolo which uses a 13700 as the LFO, there's a stompswitch to select between two speed controls, with a slew limiter so the transition between the two speeds is gradual. I'm just finishing up a multimode envelope follower for guitar using a 13700 as a HP/BP/LP VCF.
My work with the 13700 has been based on its data sheet, and grafting Roland 100m front ends for the CV inputs where needed. All of the above are applications where stability/tracking isnt an issue.
My DIY modular is built around Oberheim SEM VCOs, SEM and Moog Prodigy VCFs, Roland 100m VCAs, EGs, S/H, Noise. It started out as an expansion of my original Roland 100m, hence its mostly Roland clone stuff.
What I'm wondering is there a temperature stable 1 volt/octave LM13700 VCO design/schematic with a decent waveform set, sync etc. Anyone know of one? I guess I have an urge to build a mini modular using 13700 for everything - VCOs. VCFs, VCAs and RM. Or is it just not a suitable device for precision applications? Then again CA3080 filters seem to track pretty well, so why shouldn't LM13700 VCOs do the same? Is such an animal doesn't exist should I design one? Any hints, tips or advice?
http://www.frequencycentral.co.uk/
Scott Stites
Audio files: 96
PostPosted: Sun Dec 14, 2008 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Thomas Henry's 21st Century Synth book (the one you can get from Magic Smoke) has a great LM13700 VCO in it.
My Site
frequencycentral
PostPosted: Sun Dec 14, 2008 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
So it can be done - excellent! Does anyone have a schematic they could throw my way?
andrewF
PostPosted: Sun Dec 14, 2008 3:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
haven't tried it -
the full article is here -
http://www.jiisuki.net/reports/howto-build-analog-synth.pdf
(schematics in the appendix)
frijitz
Audio files: 54
PostPosted: Sun Dec 14, 2008 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
The two discussed here work very well:
http://electro-music.com/forum/topic-19841.html&postorder=asc
Ian
bubblechamber
PostPosted: Sat Dec 20, 2008 10:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
i've built a very stable 13700 VCO using the design off the data sheet(which is remarkably close to Thomas Henry's) and adding a variation of Thomas Henry's expo converter, but just about any expo converter that's meant for a 3080 based VCO will work. i'd breadboard the VCO and on a separate breadboard build a couple of expo converters and see which one you like the best. i went through 5 or 6 before i found one that i really liked.
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
ryktnk
PostPosted: Sun Dec 21, 2008 3:45 am    Post subject: Reply with quote  Mark this post and the followings unread
hello
I agree with Mr bubblechamber, the VCO in the Technotes
works very well.
I used the TH VCO1 expo converter with a THAT 320 Dual PNP
http://www.thatcorp.com/300-series_Matched_Transistor_Array_ICs.html
Tracking is great - about 7-8 octaves.
More accurate than a Roland 100m VCO !
-ryk
jano2358
PostPosted: Tue Apr 21, 2009 2:28 pm    Post subject: i can't ressist to say it :( Reply with quote  Mark this post and the followings unread
sorry but you web site SUCKS!!! it's hurt my eyes!
PostPosted: Tue Apr 21, 2009 2:34 pm    Post subject: Re: i can't ressist to say it :( Reply with quote  Mark this post and the followings unread
What, where, who? Shocked
Oh and welcome of course!
frequencycentral
PostPosted: Tue Apr 21, 2009 3:25 pm    Post subject: Re: i can't ressist to say it :( Reply with quote  Mark this post and the followings unread
Hehehe - I think he means me:
Builds: http://www.myspace.com/doctoranalogue
Shocked
PostPosted: Tue Apr 21, 2009 3:47 pm    Post subject: Re: i can't ressist to say it :( Reply with quote  Mark this post and the followings unread
Shocked
Laughing its wild enough for sure!
