 Forum index » DIY Hardware and Software » Musical Interfaces
Front Panels
Page 1 of 1 [8 Posts]
hway23
PostPosted: Thu Dec 18, 2008 1:57 pm    Post subject: Front Panels Reply with quote  Mark this post and the followings unread
All my synth projects have been all to amateur looking because of one problem. FRONT PANELS! ARRG! Shocked I started it with random boxes around my house. Than when I built my soundlab mini, and housed my 8 step sequencer, I cut my panels from sheet metal. (which looks not all that great btw.) So my question is: Is there a place (like home depot?) where I can by pre cut aluminum rectangles? And for under $15? ( I am going to start building my fully patchable modular soon I hope ) Very Happy
PostPosted: Thu Dec 18, 2008 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Try and find a local aluminium supplier.
My closest one is in Coffs Harbour, which is a bit of a drive, but when I get there,....
They cut any sheet, angle etc. to size on the spot (square and to the nearest mm!) and they still end up %20-30 cheaper than any hardware store.
RF
Audio files: 28
PostPosted: Thu Dec 18, 2008 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I get aluminium panels cut to size from scrap 'drops' at a nearby metal fabrication shop. They charge me one dollar per panel for 1/8 inch metal.
I used to just buy the 'drops' and cut them to size myself - it was marginally less expensive that way - but I have a better chance of not losing any of my digits by having them do it.
bruce
[EDIT] The panels I have them cut are are generally 10.5 *2.25 * 1/8 inch aluminium
www.sdiy.org/rfeng
mark_olson
PostPosted: Fri Dec 19, 2008 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I get .080 5052 aluminum sheet in 6" x 48" pieces for about $10.00 from cutsmetal.net. Since I am totally making stuff up as I go, so far haven't used a standard width for anything, but everything IS 6" high.
From what it says on their Web site you could probably have them cut pieces to size for a small charge.
Mark
KaZpeR
PostPosted: Wed Dec 24, 2008 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
front panel express
why don't you make it look good...
ChrisSousa9
PostPosted: Mon Dec 29, 2008 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
OnlineMetals.com can get you custom cut sheet metal. I bought some for my WSG project for about $12 for custom cut including S&H
www.soundabstract.net
"Overprotecting intellectual property is as harmful as underprotecting it. Culture is impossible without a rich public domain. Nothing today, likely nothing since we tamed fire, is genuinely new: Culture, like science and technology, grows by accretion, each new creator building on the works of those who came before. Overprotection stifles the very creative forces it's supposed to nurture." - Alex Kozinski, Ninth Circuit Federal Court of Appeals Judge
Danno Gee Ray
PostPosted: Mon Dec 29, 2008 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some hobby stores carry sheet aluminum. If they sell model train supplies and parts chances are they sell the aluminum panels. I buy mine there and they are .163" thick if I recall. They work rather well and are relatively inexpensive.
Ricko
Audio files: 27
PostPosted: Sun Mar 01, 2009 9:27 am    Post subject: Where in Coffs, Uncle K? Reply with quote  Mark this post and the followings unread
Uncle Krunkus:
I am frequently in Coffs Harbour: where is that aluminium store?
Rick
