PopCode
Posted: Tue Dec 23, 2008 10:07 am Post subject:
Server Failed To start |
Hello,
i'm new to SupeCollider and new to Linux .
I'm from France.(so it's for my bad english)
I'have work a little bit on SC on my computer under Ubuntu 8.10, and today he said to me :
Code: |
booting 57110
exception in GrafDef_Load: UGen 'AnalyseEvents2' not installed.
while reading file '/home/toto/share/SuperCollider/synthdefs/segmentation2.scsyndef'
while reading file '/home/toto/share/SuperCollider/synthdefs/analyseeventsdatabase2.scsyndef'
while reading file '/home/toto/share/SuperCollider/synthdefs/analyseeventsdatabase1.scsyndef'
while reading file '/home/toto/share/SuperCollider/synthdefs/segmentation1.scsyndef'
jackd 0.116.1
Copyright 2001-2005 Paul Davis and others.
jackd comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK compiled with System V SHM support.
loading driver ..
creating alsa driver ... hw:0|hw:0|1024|2|48000|0|0|nomon|swmeter|-|32bit
control device hw:0
configuring for 48000Hz, period = 1024 frames (21.3 ms), buffer = 2 periods
ALSA: final selected sample format for capture: 16bit little-endian
ALSA: use 2 periods for capture
ALSA: final selected sample format for playback: 16bit little-endian
ALSA: use 2 periods for playback
JackDriver: client name is 'SuperCollider'
JackDriver: connected alsa_pcm:capture_1 to SuperCollider:in_1
JackDriver: connected alsa_pcm:capture_2 to SuperCollider:in_2
JackDriver: max output latency 21.3 ms
JackDriver: connected SuperCollider:out_1 to alsa_pcm:playback_1
JackDriver: connected SuperCollider:out_2 to alsa_pcm:playback_2
Exception in World_OpenUDP: unable to bind udp socket
JackDriver: max output latency 0.0 ms
RESULT = 1
ERROR:
server failed to start
So i don't have any sound.
If somebody can help me ...
Thanks |
dewdrop_world
Joined: Aug 28, 2006 Posts: 858 Location: Guangzhou, China
PopCode
Posted: Tue Dec 23, 2008 2:38 pm Post subject:
Ok, one computer reboot and now working... |
