 Forum index » DIY Hardware and Software » Supercollider
AmbiEM library // KemarHRTF
Post new topic   Reply to topic Moderators: v-un-v
Page 1 of 1 [2 Posts]
PopCode
PostPosted: Tue Dec 23, 2008 2:54 pm    Post subject: AmbiEM library // KemarHRTF Reply with quote  Mark this post and the followings unread
I try to send thispart of code :
Code:
// The speaker positions [eleveation],[azimuth]
e = [90,40,40,40,40,0,0,0,0,0,0,0,-40,-40,-40,-40];
a = [0,45,135,225,315,25,75,130,180,230,285,335,0,90,180,270];
// adjust your path to the Kemar data
// this is relative to the SC3 folder
Kemar.path = "KemarHRTF/"
Kemar.initBuffers(a, e);
and I get this result :
Code:
ERROR: Primitive '_FileLength' failed.
Failed.
RECEIVER:
Instance of File {    (B75EDB70, gc=44, fmt=00, flg=00, set=01)
  instance variables [1]
    fileptr : nil
CALL STACK:
   MethodError:reportError   093C2340
      arg this = <instance>
   Nil:handleError   093C23A0
      arg this = nil
      arg error = <instance>
   Thread:handleError   093C22E0
   Object:throw   093C2220
   Object:primitiveFailed   093BA450
   Meta_Kemar:loadFileFor   B7611E20
      arg this = class Kemar
      arg azi = 0
      arg elev = 90
      var fileL = <instance>
      var fileR = nil
      var cL = nil
      var cR = nil
      var stringAzi = [*2]
   Meta_Binaural:loadBuffers   B7611B50
      arg azi = 0
      arg elev = 90
      arg bufPair = [*2]
      var cL = nil
      var cR = nil
   ArrayedCollection:do   09410B00
      arg this = [*16]
      arg function = <instance>
      var i = 0
   Meta_Binaural:initBuffers   B760E440
      arg azi = [*16]
      arg elev = [*16]
      arg server = <instance>
      arg firstBufNum = nil
   Interpreter:interpretPrintCmdLine   B760DF20
      var res = nil
      var func = <instance>
      var code = "Kemar.initBuffers(a, e);"
   Process:interpretPrintCmdLine   093B8CE0
I have downloaded Kemar at this adress :
http://sound.media.mit.edu/resources/KEMAR.html
and put my folder KemarHRTF/ in my SuperCollider folder app that i can see with this :
Code:
Platform.userAppSupportDir
But maybe i forget something... I have copied all .dat from Kemar/full/elev0... to Kemar/
what's wrong?
somebody know?
thanks...
dewdrop_world
PostPosted: Tue Dec 23, 2008 6:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Code:
RECEIVER:
    fileptr : nil
Since fileptr in the File is nil, the OS could not open the file. Possibly a wrong path?
I haven't used these classes, not sure exactly how to fix it - but I can say for sure the "FileLength failed" error is because the file is not open.
hjh
Niio1
