Power (Voltage) stabilisation
Page 1 of 1 [2 Posts]
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Jan 23, 2009 10:08 am    Post subject: Power (Voltage) stabilisation
Subject description: What to choose?
Hi guys,
In other forums about synths there are sometimes questions about synth which fail to function due to the bad power deliveries by the providers, special in the USA.
See http://electro-music.com/forum/post-225150.html#225150
Do you know what gear is the best solution to these kinds of problems?
Stabilisators or what are they called?
Wout
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jan 23, 2009 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
UPS I'd say ... as in Uninterruptible Power Supply ... a thing having a rechargeable battery to fill any power gaps and also reconditioning the mains supply continuously ... for synths having an analog power supply (like the Nords) it better be a good one having an approximately sine shaped wave of approximately the right voltage and frequency (50 or 60 Hz depending on country). A bit heavy though ... with the usual lead acid battery ... and not really cheap either.
