CALL FOR PARTICIPATION: A WINTER STREAM 09
Page 2 of 5 [103 Posts]
Audio files: 31
PostPosted: Tue Feb 17, 2009 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Preferred Start Time (GMT/UTC): after 0130 GMT (Sunday, 730pm, CST)
Name (stage name if there is one): Kevin Kissinger
Real name: Kevin Kissinger
Username: kkissinger
Set Length (30 or 60 min.): 30, 60 is possible if needed.
I have been experimenting with looping with clock sync with my Aries synthesizer and getting some intriguing results.
Expect to hear music that is ambient with some "grooves" that will come and go as I build loops that are sync'd to the clock.
The Aries is now 33 years old, it makes great sounds, and is all the more flexible with the use of live-looping equipment.
Inventor
Audio files: 267
PostPosted: Tue Feb 17, 2009 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, folks, I have a problem with an easy solution. We've done testing in the chatroom and my 5 year old Mac just doesn't have the CPU power to do the job. So I need someone to stream my broadcast for me.
If you have any operating system except Vista, then you can run ChucK with my music generation program. It runs all by itself so all you have to do is start it up and let it run for an hour, streaming at 128kbps 44kHz stereo.
So if you'd like to do that, I'd really appreciate it. Plus bonus: you'll have a way cool No Wave music generator all set up on your system as a result! Who can resist that joy? Haha, just post here if you would like to help, and thanks!
Ganzha
Audio files: 27
PostPosted: Wed Feb 18, 2009 12:48 am    Post subject: in live streaming
Subject description: calling for participation
GMT 6AM (in Almaty - Central Asia6PM)
Name - Ganzha (live in Almaty studio)
Location Central Asia - Kazakhstan- Almaty
Real Name - Vadim Ehrlich
Username - Ganzha
Set Lenth - 60 min
Date 22 Feb
http://ziart.kz
shanemorris
Audio files: 83
PostPosted: Wed Feb 18, 2009 5:17 am    Post subject: tentative schedule
Subject description: tentative schedule
Here is a tentative schedule of times for Sunday. We will finalize if this works for everyone...Please note: If you play for 60min your name is written twice.
If there are any problems with times please let me know asap please. Very Happy
At present, there are 16 performers from 3 continents for over 13 hours of Live streaming experimental music!
If you do NOT have your Port/P.W. yet...then you need to contact mosc_ asap.
17:00 Plastixman
17:30 Plastixman
18:00 Slate
18:30 Mystahr
19.00 Mystahr
19:30 Inventor
20:00 Inventor
20:30 Antimon
21:00 Modulator ESP
21:30 EdisonRex
22:00 Edison Rex
22:30 Shane Morris
23:00 Shane Morris
23:30 The Amber Portal
24:00 Astronota
24:30 OCP
01:00 OCP
01:30 Kevin Kissinger
02:00 Kevin Kissinger
02:30 Blue_Hell and Magnatron
03:00 Blue_Hell and Magnatron
03:30 Earthgirl
04:00 Earthgirl
04:30 Ganzha
05:00 Ganzha
05:30 Mosc
06:00 Mosc
ElectroCasa
mtvic
PostPosted: Wed Feb 18, 2009 4:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just found out I will be out of town on Sunday. Drag....... {-:
Darn it.
Well if I get back in time I will be listening.
m
Jason
PostPosted: Wed Feb 18, 2009 5:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes this is going to be a fun and an exciting event!
We encourage all of those who have not already done so, to test their stream
and set things up now. Testing on the day of the event will not be a good idea at all, as we will be very busy.
Feel free to come to the chat-room and we can assist you.
http://www.electro-music.com/forum/chat.php
Audio files: 213
G2 patch files: 319
PostPosted: Wed Feb 18, 2009 5:36 pm    Post subject: Re: CALL FOR PARTICIPATION: A WINTER STREAM 09 Reply with quote  Mark this post and the followings unread
Or to quote Shane
shanemorris wrote:
It is IMPERATIVE that everyone test their connections before we start streaming. At least 24 hours before or sooner. Sorry, but musicians WILL NOT be allowed to stream on Sunday if you do not test 24 hours before hand. Not only does it delay the schedule, but causes unneeded stress on performer, server operator, and audience during performance time. :wink:
So please step into the chat room soon!
Audio files: 261
PostPosted: Wed Feb 18, 2009 6:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've tested mine OK, do you want me to try it with someone else listening?
Audio files: 31
PostPosted: Wed Feb 18, 2009 9:11 pm    Post subject: I will test tommorrow (Thursday) Reply with quote  Mark this post and the followings unread
Is the test server up and running? I presume that I use the same port that I used for the NYE event.
Inventor
Audio files: 267
PostPosted: Wed Feb 18, 2009 11:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, never mind about my request for someone to run my software, I bought a netbook today and got it working with help from the folks in the chatroom. I also figured out something cool which is that you can route your headphone output back into your line-in jack with a Y cable to accomplish audio routing. This is good because windows has no Jack or Soundflower audio routing freeware. cheers!
shanemorris
Audio files: 83
PostPosted: Thu Feb 19, 2009 2:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Darn it.
m
too bad you cant make it mvic... Crying or Very sad ...but there is always next time! hope you can listen in and join the fun in the chatroom!
ElectroCasa
Audio files: 261
PostPosted: Thu Feb 19, 2009 3:10 am    Post subject: Re: I will test tommorrow (Thursday) Reply with quote  Mark this post and the followings unread
I think shane said you would get a new one assigned, with a new passward and to contact mosc if you hadn't been given one yet
doomtube
PostPosted: Thu Feb 19, 2009 3:27 am    Post subject: http://www.ustream.tv/channel/electro-music-radio Reply with quote  Mark this post and the followings unread
please sent me a photo of your self if you want it featured in the ustream of visual oddness i will run at the above address in response to your tunes..
doomtube@gmail.com
Or pm me!! i hope that the actual ustream live cast will be embeded into the electro-music-radio page.
Jason
PostPosted: Thu Feb 19, 2009 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
kkissinger: yes contact Mosc for port info please they are not the same as NYE
modulator_esp - yes it is a good idea for someone else to test your stream just in case
Audio files: 261
PostPosted: Thu Feb 19, 2009 9:01 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, I'll do it tonight
TBH I'm more worried about getting in the chat room, but I have installed a new chat thing so maybe I'll be more lucky
Jason
PostPosted: Thu Feb 19, 2009 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I am sorry to hear you are having issues with the chat room modulator_esp
but I have to say the chat room has never worked better and we are up to a record number of active users!
Something must just be off with your software etc.
Best to test this as well now instead of waiting until the last minute.
If you need some help you can PM me if needed,
we will do whatever we can to help you.
Thank you,
Jason
mtvic
PostPosted: Thu Feb 19, 2009 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Shane
Thank you
Yeah,next one for sure ,and I will listen in and chat it up when I return home Sunday eve.
m
Audio files: 213
G2 patch files: 319
PostPosted: Thu Feb 19, 2009 9:36 am    Post subject: Re: CALL FOR PARTICIPATION: A WINTER STREAM 09 Reply with quote  Mark this post and the followings unread
In the first message in this thread, and on the radio page there was written :
shanemorris wrote:
It would be best if everyone could stream at 128 kbps, 22 kHz , stereo if possible.
This is a mistake, and entirely my fault ... it should read :
128 kbps, 44.1 kHz , stereo
Sorry for this, I'll fix it in the original message too.
Edit : ok, that fixed it on the radio page too.
Audio files: 140
PostPosted: Thu Feb 19, 2009 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
The Java chat application that has worked so well for years is getting old. It apparently doesn't work to well with the latest Java releases. I've stopped using it and I use a separate program on my PCs (Trillian).
Anyway, if anyone is familiar with some other program, preferably web based, that has been proven to work, please let me know via PM and I'll see if we can't replace the Java client. Doing this is one of many things on my to-do list to improve the experience here.
BTW, many of you know we have been having lots of problems with the shoutcast servers we run. Well, I'm pretty sure we have finally sorted this problem out. Things seem to be working fine lately. Thanks to all those on the chat room who so patiently worked with me as I experimented to get this sorted out. electro-music.com is really a community.
Audio files: 261
PostPosted: Thu Feb 19, 2009 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you,
Jason
I had issues on new year's eve, but then I was using the web based java thing. I'll try my new chat client later too Smile
Audio files: 213
G2 patch files: 319
PostPosted: Thu Feb 19, 2009 10:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I've been connected here for 222:22, so almost 4 hours without any hickups ... not in the down stream to here and not in the up stream from my home ... meanwhile people have been connecting and disconnecting all the time ... also noted your message on the chat .. I should have gone to bed just a little bit later Wink
Anyway, it is way better now, and I stopped going nuts.
A chat thingy working well for me is ChatZilla, it runs on top of FireFox (not a web based solution, just a free IRC client). But then again ... the java thingie seems to work for me too ... even on Vista ...
shanemorris
Audio files: 83
PostPosted: Thu Feb 19, 2009 11:01 am    Post subject: CHATZILLA Reply with quote  Mark this post and the followings unread
Yeah ... try CHATZILLA , if you use firefox. It's great!
ElectroCasa
Inventor
Audio files: 267
PostPosted: Thu Feb 19, 2009 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
You said it Howard. I second that remark. I <3 electro-music.com!
Let's make a bumper sticker: I heart electro-music.com.
Haha, no, but it's great to be part of a community.
Inventor
Audio files: 267
PostPosted: Thu Feb 19, 2009 12:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
BTW, I went to Radio Shack today and got a Y connector for routing audio from my headphone jack back to my line-in Jack. It was under seven bucks, part number 42-2496. I don't much like Rat Shack but this is a sweet little cable, very portable and lets me listen to my broadcast while sending it back to the broadcast software flawlessly (as far as i know).
Note that for my computer, an Acer Aspire One netbook, I need to have the headphones connected to the Y or it won't work. This is OK since I want to listen anyway. On another computer you might get away with a straight cable instead of a Y, whatever works eh?
So cheers and happy audio routing!
Audio files: 261
PostPosted: Thu Feb 19, 2009 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
chat & stream are both tested OK Very Happy
