Hi! Ia mready to start! 8068 - Ganzha
Page 1 of 1 [3 Posts]
Ganzha
Audio files: 27
PostPosted: Sun Feb 22, 2009 4:32 am    Post subject: Hi! Ia mready to start! 8068 - Ganzha Reply with quote  Mark this post and the followings unread
HI1
HERE i am
 Filesize:  968.58 KB
 Viewed:  490 Time(s)
http://ziart.kz
Audio files: 277
PostPosted: Mon Feb 23, 2009 7:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed I missed this one ... was in the chat all the time for preparing the streaming ... had expected you there ... and was thinking that you had forgotten about it ... and so we changed the program to work around that hole in the program ... it is only today that I found time again to read through the forum ... I'm really sorry things went this way, I would have loved to hear you stream.
shanemorris
Audio files: 92
PostPosted: Tue Feb 24, 2009 9:11 am    Post subject: so sorry Reply with quote  Mark this post and the followings unread
Golly Ganzha....
im so bummed that we missed you...i was looking forward to your sounds.
next time, be sure to coordinate your set with the use of the chatroom. i noticed that you were coming in and out of the chatroom a lot at the beginning of the festival...then i didnt see you again.
the chatroom must be used for streaming...otherwise we won't know if you are present and ready to play. there will always be a prelimary test again on event day to make sure you are still streaming to the server. chatroom is undoubtedly the way to make sure that happens....FYI.
hope you can stream with us at the next event Ganzha. I will be sure to let you know.
shane
ElectroCasa
