 Forum index » How-tos
Logic question
Page 1 of 1 [2 Posts]
aquanaut
PostPosted: Thu Sep 02, 2004 1:25 am    Post subject: Logic question Reply with quote  Mark this post and the followings unread
anybody know how to have a fader in the environment that respond to different note number. Now the fader is only responding to a single note number and moving according to velocity values and the transformer object does'nt seem to be able to transform velocity values into note numbers. that would have been a work around. I'd like a random one octave arp changing the values of a fader and the fader changing the values of a cable switcher.Quid??
trash
PostPosted: Thu Sep 02, 2004 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
theres these little lines in the transformer
if you click on the top you can click from note to velocity
you can also change what affects a fader in the input column of the parameters bit...
hope this helps
duh
