  Twyndyllyngs live. Chez Mosc
Interval timer
ark
G2 patch files: 31
PostPosted: Mon Mar 23, 2009 3:22 pm    Post subject: Interval timer
Subject description: Remember how long elapsed between two events
Press the "Begin" button (page A1, dial 1), then press the "End" button (page A1, dial 2). After that, press the "Replay" button and the G2 plays a tone for as long as elapsed between pressing "Begin" and pressing "End."
The technique is to use an LFO set to the longest possible duration (62.9 seconds) and a sample-and-hold to remember the LFO's level at the time of the second button press. But the duration is pretty fine-grained because the LFO output has 24-bit resolution (or so I believe).
I'm thinking that this technique, coupled with a Delay Clocked module to store up to 128 levels, might be useful for making an interactive phrase sequencer, in which you play a phrase at it and it remembers it for you for replay later on.
Interval timer.pch2
Go to parameter page A1, then press Begin and then End. After that, pressing Replay will play a tone for the length of time that elapsed between Begin and End, up to 62.9 seconds.
 Filename:  Interval timer.pch2
 Filesize:  1.41 KB
 Downloaded:  915 Time(s)
