pitchbend delay filter
Page 1 of 1 [5 Posts]
avetrex
PostPosted: Wed Apr 01, 2009 4:29 pm    Post subject:  pitchbend delay filter
Subject description: need help removing distortion, tempo synching to external source and turning input into stereo
need help removing distortion (only certain variations on 1-8 will distort the incoming signal at one point in the cycle??, tempo syncing to external source (sequencer or sound card) just need to see an example of how to work MIDI tempo syncing into a patch. and turning input into stereo ( it only seems to take audio from 1 of the 2 inputs???
any input would be great
thank you in advance
Brandon
njv 2 point OH.prf2
pitch bend delay filter (works nicely on voices or sounds with pauses in-between them)
need help removing distortion, tempo syncing to external source and turning input into stereo
see post above
 Filename:  njv 2 point OH.prf2
 Filesize:  13.44 KB
 Downloaded:  533 Time(s)
avetrex
PostPosted: Thu Apr 02, 2009 5:18 am    Post subject:  revision
Subject description: ..
forgot to add above the distortion problem may only happen when the mod wheels are moved to a certain position the effect is also much more interesting if you play the 3 mod wheels and on a few variations the pitch bend (this effect was made on a g2x)
grimley
G2 patch files: 9
PostPosted: Fri Apr 03, 2009 8:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not sure about your distortion problem but take a look at the simple patch I attached demonstrating stereo processing.
Simply set your patch to 2 voices and use the "Voice No." output of the "Status" module to determine which voice is being processed (see blue modules top left). To sync to an external midi clock just set your clock module to master and in the patch settings make sure "Ignore external clock" is unchecked.
Oh, and welcome! welcome
-Justin
StereoProcessor.pch2
 Filename:  StereoProcessor.pch2
 Filesize:  2.82 KB
 Downloaded:  549 Time(s)
avetrex
PostPosted: Sat Apr 04, 2009 3:31 am    Post subject: thanx Reply with quote  Mark this post and the followings unread
thank you so much appreciate it, the distortion thing is weird its a digital distortion that only happens on some variations when the modwheels are set in a certain position lol if i have time ill mess w the patch and post what position the wheels need to be at and which variation
arecio
PostPosted: Sun Jun 14, 2009 8:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Your patch sounds interesting, and the aproach maybe is similar of what I was looking for...can you read my post here? : http://electro-music.com/forum/topic-34805.html
mps board
