1.24 update problems!!
Page 1 of 1 [3 Posts]
PostPosted: Tue Sep 07, 2004 9:54 pm    Post subject: 1.24 update problems!! Reply with quote  Mark this post and the followings unread
My new G2 came with 1.0 installed. So I downloaded 1.24, and ran the synth update utility.
It connected to the G2, and recognized 1.10
I clicked "Update", the updater initiated a reset to the synth, instantly went to 100% & closed itself. Al in less than a second.
Now the synth is stuck in "USB recv v1.24" on the master LCD. All others are blank. Of course, the manual says under no circumstances do I reboot until the update is complete. I'm writing to Clavia, but anyone see this (or know what to do)Exclamation Exclamation Question
ian-s
Audio files: 42
G2 patch files: 625
PostPosted: Tue Sep 07, 2004 9:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Run the updater again.
PostPosted: Tue Sep 07, 2004 10:17 pm    Post subject: Use shorter cables! Reply with quote  Mark this post and the followings unread
Tried that it failed. So I figured I'd reboot (power cycle)...it booted to 1.10 (expected this).
Well, to be brief, the G2 did NOT come with a USB cable, as others have noted. So I had used the nearest one, which works for my emagic AMT8.
Remembering some USB2.0 problems with other gear, I swapped out that cable for a shorter one, and everything worked as described.
Excuse me for the premature phreak out...But hopefully this helps someone else who runs into a similar problem.
