parts name?
Page 1 of 1 [3 Posts]
if837
PostPosted: Wed Apr 15, 2009 6:13 am    Post subject: parts name? Reply with quote  Mark this post and the followings unread
Whats the parts name of the component to connect/wiring from pcb board to potentiometers ?
edit: I answer it myself: PCB Terminal Blocks (connectors)
numbertalk
PostPosted: Wed Apr 15, 2009 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Do you mean this, an MTA header (the one that goes on the board) and receptacle (the one that is wired up to the pot and plugs into the header):
http://www.mouser.com/Search/ProductDetail.aspx?R=640454-3virtualkey57100000virtualkey571-6404543
http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMvT7Of4ktfHLkC6EFvng%252b5U6YhgIYDqzzs%3d
For pots these generally will be at .100" spacing but be careful - some connections for some boards are .156", usually power connectors (this is the MOTM standard power connector spacing).
Also, if this is your first time using these you might find this thread helpful:
http://electro-music.com/forum/viewtopic.php?highlight=mta+screwdriver&t=22028
if837
PostPosted: Wed Apr 15, 2009 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for taking time, aswering. I´m not sure if this is the right component. It on the Yusynth vco LM394 layout, wiring from pcb board to potentiometers.
