synthmonger
DGTom
Posted: Tue Apr 28, 2009 2:12 am Post subject:
Cool! I have your 40106 VCO on my breadboard at the moment, would this be best used straight off the output pin or from one or other of the "proper" waveform outs? |
synthmonger
Posted: Tue Apr 28, 2009 5:02 am Post subject:
If you're using the VCO with the 4016 switch that is acting as a voltage controlled variable resistor on one of the spare 40106 gates yes it would work. Triggers are the only thing this can't handle. Anything else, normal square, triangle, sine, saw etc will work. Negative voltages too. _________________ Youtube!
modular demos!
Whacky tunes! |
synthmonger
synthmonger
DGTom
Posted: Wed Apr 29, 2009 4:01 am Post subject:
I've been playing around with your 'super simple vco' with a transistor for the CV in, cos I blew my only (for the time being) 4007 up w/ the 4007 I used the current source drawing (I think) slacker posted up here, that worked great.
Gonna search for the info on the 4016 idea now
So these are really intended as standalone PWM everything! Nice. |
monokinetic
Posted: Wed Apr 29, 2009 6:46 am Post subject:
Hey synthie!
Hmmm, sounds intriguing I had a quick look at the PCB and schematic (Bananas are indeed delish!). But I'm not 100 percent sure I understand what you have here:
It seems to be 2x PWM oscillators, CV controllable. Is that correct?
I think there are 6 pots on the PCB, but only 4 on the schematic (or is the trim on the front panel?).
Sorry if these are obvious questions, I'm just double-checking before I head over to your etsy store, assuming this is what I think it is
David |
synthmonger
Posted: Wed Apr 29, 2009 12:20 pm Post subject:
monokinetic wrote: | Hey synthie!
David |
It's not two PW oscillators but two circuits that take any input waveform (guitars, toys, and the like will need amplification) and outputs a 0 to +5v square wave whose duty cycle is variable via CV. There are only Two pots, one for each pulse width, of course you could add more for PWMOD and each output. I use 3.5mm switching jacks from all electronics and I have added mounting places for them on the pcb.
I etched the boards but was too tired to drill them. They'll be available later tonight or tomorrow after I make sure they're good to go.
Edit: two panel mounted pots and two trim offset pots. One for each PWM. _________________ Youtube!
modular demos!
Whacky tunes! |
synthmonger
