Arduino MIDI Velocity Sensitive Drum Controller
Page 1 of 1 [4 Posts]
dshay
PostPosted: Mon May 04, 2009 5:34 pm    Post subject: Arduino MIDI Velocity Sensitive Drum Controller Reply with quote  Mark this post and the followings unread
Howdy y'all.
I recently created a project, wrote an algorithm to read force sensing resistors (FSRs)
(Interlink sensors, you can get them from places like Trossen Robotics)
FSRs are the type of sensor used by Trigger Finger, Akai, and most keyboards with velocity sensitivity.
The reason I used these sensors is because this drum controller is wearable, it straps to my bicep. It's wireless, I use an Xbee configured to 31250 baud rate (ATBD7A12 is the AT command)
Anyways, my code is opensource, copyleft, and you can figure out how to interface these sensors if you read some of Tom Igoe's material.
Photobucket
It's just a simple voltage divider, sensor in series with 10k ohm resistor and an analog input on the Arduino measuring the voltage across the resistor.
Hook one one leg of the sensor to 5V, the other to the resister, the other end of the resistor to ground, and where the resistor and sensor meet, attach an analog input from the microcontroller. I'll draw up a schematic when I'm out of finals. The code can be found here:
http://arduino.pastebin.com/d174bf57f
Audio files: 116
G2 patch files: 317
PostPosted: Mon May 04, 2009 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool project!
welcome
dshay
PostPosted: Tue May 05, 2009 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
The code expired on that host, I reposted it:
http://arduino.pastebin.com/mab7f488
anotherscott
PostPosted: Thu Sep 08, 2011 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see the info is gone again, any chance of a repost? I'm actually looking into creating a single small velocity sensitive pad that will send out a MIDI note when struck. Any leads appreciated...
Niio1
