atari punk console problem (ticking)
Page 1 of 1 [5 Posts]
dfgsdfg
PostPosted: Thu May 14, 2009 1:03 am    Post subject: atari punk console problem (ticking) Reply with quote  Mark this post and the followings unread
so i breadboarded an apc using this layout Posted Image, might have been reduced in size. Click Image to view fullscreen. and it seems to work, as in sound is coming out of it and the pots are working and everything but all im hearing are ticks.. and the speed of the ticking is changed when i turn the pots... theres nothing too fancy about it though... does anyone have any ideas as too why?
PostPosted: Thu May 14, 2009 1:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds like the caps are too large, are you sure you've got the right values?
dfgsdfg
PostPosted: Thu May 14, 2009 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
im using a .1uf for 10nf, and a .01 uf for the 100nf, is this equivalent?
Audio files: 278
PostPosted: Thu May 14, 2009 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Use the following substitutions instead :
.1 uF = 100 nF
.01 uF = 10 nF
dfgsdfg
PostPosted: Thu May 14, 2009 10:24 am    Post subject: Reply with quote  Mark this post and the followings unread
i figured it out.. when i take out the c1 cap, it works!
