PAIA Fatman
Page 1 of 1 [5 Posts]
PostPosted: Fri May 15, 2009 10:21 am    Post subject: PAIA Fatman
Subject description: Skrog new build panel layout
Hello, next project beckons Smile ,
Reworking my fatman to a more condensed case to make room for AMS2 synth due to build after summer.
Mod's used this time on the Fatman synth....
2 sub osc's.
ring mod.
2nd vcf.
bass boost.
3 more adsr's.
osc sync.
4 lfo's
Panel done in corel draw 12 saved as jpeg
i'll post some pics & sounds when done.
 Filesize:  324.77 KB
 Viewed:  901 Time(s)
Dan Lavin
Audio files: 21
PostPosted: Sat May 16, 2009 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dang! That's huge! Maybe change the name to Obeseman!
PostPosted: Thu May 21, 2009 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
construction is flying on with this one , hope to have the guts transplanted from vers. 4 to newly stickered vers. 5 by this weekend.
4 Lfo's and 2 sub osc's to build on vero board then it's wiring time again..
a few bubbles to flatten out then the pots & switches get fitted
 Filesize:  108.13 KB
 Viewed:  660 Time(s)
PostPosted: Mon Jun 08, 2009 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fab, finished the fatman housing transfer, i've been getting some great bass line sounds since doing 2 sub osc's & X-OR ring mod, the last version had 12 lfo's , parametric eq and a crackly pwm,
all been thined down to a smaller unit ,with the features up above , freeing up much needed space Very Happy . here's a few pics of before and after and some sounds from the new build.....
 Filesize:  80.01 KB
 Viewed:  620 Time(s)
 Filesize:  82.6 KB
 Viewed:  707 Time(s)
PostPosted: Mon Jun 08, 2009 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds from
behind the fatman.mp3
introducing 2 ramp wavforms then 2 sub osc's then the ring mod and a filter sweep to finish , very mode !!
 Filename:  behind the fatman.mp3
 Filesize:  961.05 KB
 Downloaded:  1441 Time(s)
sub oscs 2.mp3
sub osc's with some glide
 Filename:  sub oscs 2.mp3
 Filesize:  531.84 KB
 Downloaded:  1452 Time(s)
fatman bass line f1-f2 series & modulation.mp3
vcf1 & vcf2 switched in series with modulations, ooh
 Filename:  fatman bass line f1-f2 series & modulation.mp3
 Filesize:  327.82 KB
 Downloaded:  1495 Time(s)
Xor 2vcfs paralel w joysticks cutoffs.mp3
X-OR ring mod on it's own going thru vcf1 & vcf2 switched in paralell
 Filename:  Xor 2vcfs paralel w joysticks cutoffs.mp3
 Filesize:  508.63 KB
 Downloaded:  1422 Time(s)
