 Forum index » Instruments and Equipment » Waldorf
trouble with 12decode MWII editor
Page 1 of 1 [4 Posts]
kofi
PostPosted: Tue May 19, 2009 1:31 am    Post subject: trouble with 12decode MWII editor Reply with quote  Mark this post and the followings unread
Hello,
I have been desperately attempting to use the 12decode editor for the microwave II. But I have had no luck.
Whatever I do in the editor I always get the message "A timeout error occured: error code 3"
I have no idea what this means. Crying or Very sad
Anyone have luck using this?
kofi
PostPosted: Thu May 21, 2009 3:05 am    Post subject: Reply with quote  Mark this post and the followings unread
A day or so later I realised that you need to have the device id on the microwave II set to same as the editor ! Embarassed
cappy2112
PostPosted: Mon May 25, 2009 6:15 pm    Post subject: Re: trouble with 12decode MWII editor Reply with quote  Mark this post and the followings unread
kofi wrote:
Hello,
What is the 12 decode editor?
kofi
PostPosted: Fri Jun 05, 2009 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
The 12 decode editor is a shareware software editor for the microwave synths which operates on os9 and os x.
As far as I know it is the only editor for the microwave that runs on os x, other than Midi Quest or Sound Diver which are of course commercial or no longer supported.
I have had no experience with any other editors that run of windows machines such as soundtower so I can compare them. However, the 12decode editor is excellent.
http://12decode.de/
