<on air> Various Artists Live streaming concert in memory of Antimon
1% metal film resistors vs 5% carbon film resistors
Page 1 of 1 [3 Posts]
Thalassa
PostPosted: Tue May 19, 2009 3:03 am    Post subject: 1% metal film resistors vs 5% carbon film resistors Reply with quote  Mark this post and the followings unread
I'm planning to build another bunch of Yusynth modules and I have a question about resistors.
I was wondering if would have significant difference between using all 1% metal film resistors or only use them where is indicated. I know that using 1% resistors will increase the price of each module between 10% - 15% but will be something that I can assume if the module will have better reliability.
What do you think?
Pablo
http://www.corsynth.com
yusynth
PostPosted: Tue May 19, 2009 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I use 5% 1/4W resistors unless 1% metal film are required when precision and thermal stability are at stake. For circuit where I need good matching but temperature stability is not required I even match 5% resistors within 1% or even 0.1% tolerance.
To answer more directly, yes go for 5% unless 1% is explicitly mentioned.
Yves
Thalassa
PostPosted: Tue May 19, 2009 3:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Yves , I will follow your advice Smile
