Joined: May 16, 2005 Posts: 8933 Location: Birmingham, England, UK
Posted: Fri Jun 05, 2009 2:04 am Post subject:
Curtis Lite. Granular synthesis for iPhone/ Touch |
Looks and sounds pretty mental!
http://thestrangeagency.com/?page_id=39
iTunes Link
_________________ ACHTUNG!
Joined: Jan 31, 2003 Posts: 18197 Location: Durham, NC
Audio files: 212
Posted: Fri Jun 05, 2009 9:34 am Post subject:
You bet! I sampled Dorothy from the Wizard of Oz this afternoon, and freaked out the kids!!
It could do with a few more options like setting markers and triggers for various points on the waveform, and perhaps some sample memory, but it's a lot of fun already- and for 59p (about one US dollar!) _________________ ACHTUNG!
Posted: Sat Jun 06, 2009 10:07 am Post subject:
Thsi looks very interesting. I have used CrusherX on my PC which is a fine VST for granular experimentation but the application looks good for my iTouch. Hmm, will it work for iTouch minus the record facility?? Hmmm The name is interesting as it is probably named after the one of the fathers of Granular synthesis, Curtis Roads
Bill |
Audio files: 278
Posted: Sun Jun 07, 2009 11:13 am Post subject:
Sweet _________________ Jan
Audio files: 278
seraph
Editor
Audio files: 33
Posted: Tue Jun 09, 2009 11:31 pm Post subject:
excellent Jan I do like it. It's pretty mental indeed You make me want to buy an iPhone _________________ homepage - blog - forum - youtube
Audio files: 212
Posted: Wed Jun 10, 2009 3:48 pm Post subject:
Jan, great piece. What do you use as the input for the Curtis program? I haven't had as good results just speaking or singing into it. _________________ --Howard
my music and other stuff |
Audio files: 278
Posted: Wed Jun 10, 2009 3:57 pm Post subject:
Thanks guys, glad you like it.
For input I just mumble and whistle into it ... but ... I find it to be working well when having some different vowels ... and some sharp s, t, k sounds are nice too. But I try to keep some silence between the sounds, as that makes it easier to explore them. Pitch doesn't matter too much, unless you also want to play it like a mini sequence (by dragging from beginning to end over the entire sample). _________________ Jan
iPassenger
Joined: Jan 27, 2007 Posts: 1067 Location: Sheffield, UK
G2 patch files: 78
Posted: Fri Jun 12, 2009 3:46 am Post subject:
Blue Hell wrote: | Thanks guys, glad you like it.
For input I just mumble and whistle into it ... but ... I find it to be working well when having some different vowels ... and some sharp s, t, k sounds are nice too. But I try to keep some silence between the sounds, as that makes it easier to explore them. Pitch doesn't matter too much, unless you also want to play it like a mini sequence (by dragging from beginning to end over the entire sample). |
Nice work that Blue, makes me feel quite uneasy, that bass sweep makes me feel quite ill. good stuff. _________________ iP (Ross)
Posted: Tue Jun 16, 2009 1:04 pm Post subject:
Oh wow what a piece Jan! Really f**king creepy!!
It's rather humbling to know that all you really need for wild experimentation, these days, is sitting right there in one's own pocket! _________________ ACHTUNG!
Audio files: 278
Joined: Feb 04, 2005 Posts: 2845 Location: Nottingham, UK
Audio files: 276
EdisonRex
Audio files: 172
Posted: Thu Nov 12, 2009 8:23 am Post subject:
I only have it on my iPhone (and I use Heavy). _________________ Garret: It's so retro.
Audio files: 276
Posted: Thu Nov 12, 2009 9:55 am Post subject:
It looks like Heavy lets you import samples via wi-fi, which might be better than trying to get some sort of mic attachment for the touch _________________ Jez
music | adventures in sound | gear for sale |
Joined: Apr 24, 2009 Posts: 2492 Location: Bristol UK
Audio files: 495
Posted: Thu Nov 12, 2009 10:21 am Post subject:
I have Heavy on iTouch and have imported a few samples, it is easy enough once you have done it a couple of times. _________________ Muied Lumens Sub Forum
Bandcamp |
Audio files: 495
Posted: Thu Nov 12, 2009 12:50 pm Post subject:
Muied Lumens wrote: | I have Heavy on iTouch and have imported a few samples, it is easy enough once you have done it a couple of times. |
I just remembered a problem I have had with this app - it never seems to load the entire sample, just a certain fraction of it, no matter the length of the sample... _________________ Muied Lumens Sub Forum
Bandcamp |
Audio files: 278
Posted: Thu Nov 12, 2009 12:59 pm Post subject:
Maybe it can only handle mono samples? _________________ Jan
Audio files: 276
Posted: Thu Nov 12, 2009 2:09 pm Post subject:
Muied Lumens wrote: | Muied Lumens wrote: | I have Heavy on iTouch and have imported a few samples, it is easy enough once you have done it a couple of times. |
I just remembered a problem I have had with this app - it never seems to load the entire sample, just a certain fraction of it, no matter the length of the sample... |
on the SA site it says
Currently short 44.1kHz 16-bit WAV files are supported. Curtis will use the first four seconds of longer files. _________________ Jez
Audio files: 495
