 Forum index » DIY Hardware and Software » Supercollider
SC 3.3 alpha6: no midi out on Vista?
Post new topic   Reply to topic Moderators: v-un-v
Page 1 of 1 [3 Posts]
djdaphalgan
PostPosted: Wed Jun 10, 2009 6:01 am    Post subject: SC 3.3 alpha6: no midi out on Vista? Reply with quote  Mark this post and the followings unread
SC 3.3 alpha6 can only find my midi in ports. Is this a bug? (I use Vista 64 bit version and SC 3.3 alpha6 is the only version that runs on my system (the old Psycollider version crashes all the time))
dewdrop_world
PostPosted: Thu Jun 11, 2009 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, MIDI out is broken in the current windows release. I'm not sure when it will be fixed.
A fix was proposed on the sc-dev mailing list but I don't think anyone has had time to test it thoroughly. I'm attaching the .diff here. You might be a good person to test it actually! But I don't know if you have MS Visual C++ sitting around... if so you can get the source code, apply the patch and build the MSVC project.
I probably should set up MSVC at some point but haven't had time.
James
portmidi.txt
.diff patch to apply to SC_PortMIDI.cpp
 Filename:  portmidi.txt
 Filesize:  8.87 KB
 Downloaded:  136 Time(s)
djdaphalgan
PostPosted: Sat Jun 13, 2009 6:30 am    Post subject: Reply with quote  Mark this post and the followings unread
James
I have no MS Visual C++ on my pc, and my C++ knowledge is rather limited (the last time I programmed something in C++ was during college, and that's allready more than 5 years ago). I can try to download MS Visual C++ 2008 Express, but someone will have to explain me what I have to do with the .diff file and how to compile the code.
