  Paulo Santos Synth-ing NºX
 Forum index » DIY Hardware and Software » Supercollider
Using a loop inside a SynthDef
Post new topic   Reply to topic Moderators: v-un-v
Page 1 of 1 [3 Posts]
nelsen
PostPosted: Thu Jun 25, 2009 12:14 am    Post subject: Using a loop inside a SynthDef Reply with quote  Mark this post and the followings unread
I'm trying to create an echo Synthdef which produces a specifiable number of echos of the input. I've tried it like this:
Code:
SynthDef(\echo, {
   arg in=0, out=0, period=0.25, feedback=0.5, repeats=4;
   var source, output;
   source = SoundIn.ar(in, 1);
   output = source;
   repeats.do({
      arg i;
      var j=i+1;
      output = output + DelayN.ar(source, j*period, j*period, feedback**j);
   Out.ar(out, output);
}).send(s);
However, I only get one echo of the input signal. If I add,
Code:
repeats = 4;
before
Code:
repeats.do...
it works, although then the number of repeats is fixed.
I guess the problem is that the loop just runs once on creation of the synthdef, but I can't think of a better way of doing this!
Thanks,
John
dewdrop_world
PostPosted: Thu Jun 25, 2009 6:14 am    Post subject: Reply with quote  Mark this post and the followings unread
You can't use a synthdef argument to control the number of repeats.
A synthdef is a fixed structure, but you're asking it to change its structure (increase the number of UGens) when you create a new Synth. That's not possible.
The loop runs just once because the server (which runs the synth) does not know ANYTHING about language flow-of-control constructs.
Easiest way is to create a function that generates a synthdef.
Code:
f = { |repeats = 4|
   SynthDef(\echo ++ repeats, {
      arg in=0, out=0, period=0.25, feedback=0.5;
      var source, output, delayed;
      output = source;
      repeats.do({
         arg i;
         var j=i+1;
   }).send(s);
f.value(4);   // creates "echo4"
f.value(3);   // creates "echo3"
Also, this small change will save some memory:
Code:
f = { |repeats = 4|
      var source, output;
      output = source;
      delayed = source;
      repeats.do({
         arg i;
         var j=i+1;
         delayed = DelayN.ar(delayed, period, period);
         output = output + (delayed * (feedback**j));
   }).send(s);
hjh
nelsen
PostPosted: Thu Jun 25, 2009 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome, thank you!
