Pic programmers
Page 1 of 1 [13 Posts]
crashlander42
PostPosted: Fri Jun 26, 2009 7:34 pm    Post subject:  Pic programmers
Subject description: breadboarding JDM programmers
I'm interested in experminting with some PIC projects. Up until now the only microcontrollerish project I've touched was thee MIIDIbox midi2cv. I was looking for a cheap pic burner that worked for the 16f628 chip and 18f452 and saw this one on sparkfun. I was curious if there were any reasons to avoid this one.
http://www.sparkfun.com/commerce/product_info.php?products_id=8
I was looking at starting with some of the projects here
http://www.electricdruid.net/forums.html?page=projects
thanks in advance for any advice.
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
crashlander42
PostPosted: Fri Jun 26, 2009 11:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
will this program thhe 16f684? I don't see it listed anywhere.
My DIY stuff Flickr
PostPosted: Sat Jun 27, 2009 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Crash,
It says on the Sparkfun page that you can use "Winpic", which in the device list the device you want to program is there:
http://www.qsl.net/dl4yhf/winpicpr.html
# dsPIC30F2010 (theoretically ALL dsPIC30F devices supported, a few tested)
# PIC16C61, PIC16C71
# PIC16C84, PIC16F84
# PIC16C710, PIC16C711, PIC16C715
# PIC10F200, PIC10F202, PIC10F204, PIC10F206
# PIC12F629, PIC12F635, PIC12F675, PIC12F683
# PIC12F609, PIC16F610, PIC12F615, PIC16F616 (new since 2007-06)
# PIC16F627, PIC16F627A, PIC16F628, PIC16F628A
# PIC16F630, PIC16F636, PIC16F648A
# PIC16F676, PIC16F684, PIC16F688
# PIC16F73, PIC16F737, PIC16F74, PIC16F76, PIC16F77
# PIC16F818, PIC16F819
# PIC16F87, PIC16F88
# PIC16F873A...PIC16F877A
# PIC16F88
# PIC18F242, PIC18F248, PIC18F252, PIC18F258
# PIC18F442, PIC18F448, PIC18F452, PIC18F458
# PIC18F2XX0/2XX5/4XX0/4XX5 (tested: PIC18F2550)
# and other "quite compatible" devices, if you have the datasheet and a text edi
crashlander42
PostPosted: Sat Jun 27, 2009 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, sweet. I missed that. I wasn't completely sure if there was hardware limitation to which chips it could burn or if it was just software. Are there any drawback to me going with this one. It is $80 cheaper than a lot of the other burners i see so it makes me kind of nervous.
My DIY stuff Flickr
PostPosted: Sat Jun 27, 2009 3:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Crash,
If these are chips , the ones you sited, that you will be working with for a while, it certainly is worth the small investment to get this small programmer. No sense in spending all the extra bucks for a more "universal" type programmer. The more expensive programmers are generally USB connected and do the job faster and is one reason they are more expensive. Functionally, the cheaper one will work, just not as fast.
If I were you, later I would purchase the Microchip ICD3 programming pod if you find your interest really peaking and move onto the bigger devices with more advanced debug capabilities.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en537580
Bill
Audio files: 278
PostPosted: Sat Jun 27, 2009 5:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
State Machine wrote:
ICD3
Just some ramblings & impressions.
Last week, for my job, I tried some debugging with the real-ice thingie from microchip, apart from that it will not show me the processor stack and that I need a special connector on my target for timing info (the stopwatch is not implemented, so I'll need a trace instead I guess) it worked pretty well I must say, almost as good as the ice 4000 and 2000 systems do. Wonder how the ICD3 would compare to that, I've used the ICD2 (and not ICD3) but was not too impressed by that one. For one the real-ice can use soft break points, allowing me more than the 3 supported by the processor itself (or 1 breakpoint even for smaller processors). Anyway, the ICD2 is a good in circuit programmer I think, but not a really good debugger ... I gave it away, sort of ... that is the workshop now uses it as an in circuit programmer for small scale production (10s to 100s, lets say).
slo
PostPosted: Sat Jun 27, 2009 8:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm a total newb too and earlier today I went for this one,
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270412251369&ssPageName=ADME:B:EOIBSA:US:1123
It's usb driven and is supposed to be compatible with the Microchips IDE which is free on their webite. As a bonus it will program in-circuit so I suppose de-bugging is possible, though not for me with newb skills.Smile
I also considered the PICkit 2 Debug express which only will program in-circuit, available from Digikey.
Have fun!
George[/url]
widdly
PostPosted: Sat Jun 27, 2009 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
The sparkfun one is based on a JDM. I built one on perf and it worked fine from my linux desktop machine. It wouldn't work with any of my old laptops serial ports. I doubt it would work from a usb-serial adapter unless it had an external 12v supply.
You could build a jdm on a breadboard first to see if it works for your serial port. If it does then solder it up on perf.
There are designs for parallel port programmers that are even simpler, if you have a parallel port sitting around.
EDIT... oops sorry parallel port programmers dont work for those modern pics
crashlander42
PostPosted: Fri Aug 28, 2009 1:53 pm    Post subject:   Reply with quote  Mark this post and the followings unread
ssoooo... I got my 16f684's in the mail and started building a simple JDM programmer on breadboard, then i noticed that this one called for a 18 pin socket (the 16f684 is a 14 pin chip). I also noticed that it mentioned that this design was limited to the 16x84. Is this limitation just the socket? can I adapt it to work with the 16f684? I'm fine with using headers and attaching them to the right pins if need be. I'm just not sure how to approach it.
http://www.semis.demon.co.uk/uJDM/uJDMmain.htm
My DIY stuff Flickr
crashlander42
PostPosted: Fri Aug 28, 2009 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
i also noticed on the sparkfun JDM programmer it says "supports 8, 18, 28 and 40 pin PIC microcontrollers"
what have they got against 14 pins?
My DIY stuff Flickr
crashlander42
PostPosted: Fri Aug 28, 2009 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
good news! i answered all my own questions with the clever use of the Google.
I built a programmer from the schematic for the one on the sparkfun page (which is the one i probably should have gone with from the start). I only killed one pic in the process (due to an unfortunate reversed transistor incident).
All is working fine now.
crappy pointless picture for no reason at all.
 Filesize:  168.79 KB
 Viewed:  270 Time(s)
My DIY stuff Flickr
Luka
PostPosted: Fri Aug 28, 2009 11:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
good stuff
im having problems getting my computer to recognise my burner
i might have to give it another shot this afternoon
problemchild
melbourne australia
crashlander42
PostPosted: Fri Aug 28, 2009 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Strangely, I didn't have a problem with that. Have you tried kicking it? worked for me.
My DIY stuff Flickr
