 Forum index » Instruments and Equipment » Waldorf
Granucon Pulse editor in XP
Page 1 of 1 [4 Posts]
Oli
PostPosted: Tue Jul 28, 2009 1:16 pm    Post subject: Granucon Pulse editor in XP
Subject description: So, is there a trick to this?
Just wondering if anyone here has had any luck running the Granucon Pulse editor under Windows XP?
For me, it exits immediately, with no error message. I have tried to observe any activity in the process under task manager, but I just see something flash on, and off again.
I have tried a few compatibility settings for the executable, too, but nothing has worked so far.
I'm wondering if this program may need a Windows component which I haven't installed. That may be my next avenue to explore, or I will try to get SoundDiver to run again.
Oli
Good good study, day day up!
wouter
PostPosted: Tue Jan 12, 2010 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
You could try to delete the settings file called pedit.ini in the directory where the program is installed (most likely C:\Program Files\Pulse Editor).
Bye,
Wouter
cappy2112
PostPosted: Tue Jan 12, 2010 7:00 pm    Post subject: Re: Granucon Pulse editor in XP
Oli wrote:
Oli
What does Granucon say about this issue?
wouter
PostPosted: Wed Jan 13, 2010 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did not configure my signature properly Wink
Electronic Music - www.insanic4.com | Music Production Resources - www.granucon.com | Netlabel - www.sonicengram.com | Multitouch Controller - www.gesturespark.com
Niio1
