 Forum index » Instruments and Equipment » Reaktor
"Raise To Power" Function
Page 1 of 1 [6 Posts]
"Minks"
PostPosted: Wed Aug 05, 2009 6:08 pm    Post subject: "Raise To Power" Function
Subject description: Can Reaktor do it?
I'm trying to implement a sigmoid shaper curve by implementing the sigmoid formula in a macro.
The formula is 1/(1+e^-t).
The problem is, I can't find a module in Reaktor (version 3) to raise a number to a power. I know there are Log and Expon modules - would that be anything to do with it?
Chet
G2 patch files: 35
PostPosted: Sat Aug 08, 2009 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Reaktor 3? Wow, that's old. Here's a solution in Reaktor 5, using the Power function (assuming that function is in Reaktor 3).
 Filesize:  5.76 KB
 Viewed:  2705 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Sat Aug 08, 2009 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know reactor, but expon sounds like x^y or maybe e^x to me.
"Minks"
PostPosted: Sun Aug 09, 2009 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm. I just had another systematic look through the modules and there is no power function. I can't believe it!
Thanks, though.
I'm tempted to upgrade but I sent some instruments I made to a mate who has version 5 and they didn't work so I assume there's no backward compatibility and I don't want to lose the use of all my creations.
Or is just because 5 was such a huge leap forward? Would v4 work with v3 ensembles?
Chet
G2 patch files: 35
PostPosted: Mon Aug 10, 2009 11:22 am    Post subject: Reply with quote  Mark this post and the followings unread
I don’t know why they wouldn’t work with V5, but some of the gurus on the NI Reaktor forum might. You could post one there and ask them to give it a try.
"Minks"
PostPosted: Tue Sep 01, 2009 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Just thought I'd post to say I've found it!
It's a macro, not a module. I don't know why I didn't think to look there - I suppose it just seemed like such a trivial function it would be a module.
http://www.myspace.com/abattleshipcalledquotminksquot
