Expo converer problems
Page 1 of 1 [3 Posts]
bubblechamber
PostPosted: Wed Aug 05, 2009 7:05 pm    Post subject: Expo converer problems Reply with quote  Mark this post and the followings unread
i'm using the expo converter from making music with the 3080 to control an OTA based VCO I've substituted a 2SA798 for the 3906s in the expo. on a bread board it works great, but every time i etch it the VCO range is about half of what it is on the breadboard design.
any ideas?
You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same.
Audio files: 22
PostPosted: Thu Aug 06, 2009 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
When you say half the range, do you mean that it tracks properly such that you get a doubling of frequency for every volt that your input CV increases but just don't cover as many octaves? This is important to know.
It should be tuned such that you (Iabc) OTA control current should double for every volt increase of the CV input if your in the square law region of the expo transistor.
Bill
bubblechamber
PostPosted: Thu Aug 06, 2009 1:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bill
well, now i have 2 problems...
on the bread board my VCO goes from about 1 cycle/minute up to about 4K and the PCB version of the same circuit goes from 60Hz-around 3K
as far as the tracking, on the breadboard it's perfect and i just did some tests with the PCB version and it's terrible, around 1.5V/oct.
i've never had a project that worked on a breadboard act so differently when etched. this is really driving me crazy.
emSynth
