Prefixes and suffixes of ICs
Page 1 of 1 [6 Posts]
LektroiD
PostPosted: Thu Aug 13, 2009 11:50 am    Post subject: Prefixes and suffixes of ICs Reply with quote  Mark this post and the followings unread
What do they mean?
For example, LM.. TL.. are known to be op amps, but why have two different suffixes for op amps, this goes for other chips, I have a pile of 4000 series chips, some are MC, some TC, some HEF, some CD, etc... what do they mean?
LektroiD
daverj
PostPosted: Thu Aug 13, 2009 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
The prefix is the manufacturer and/or series of the part. If a part is licensed from one manufacturer to another, the same prefix is often used by the other manufacturer, though sometimes the other manufacturer will use their own prefix.
The suffix contains multiple pieces of info, such as the version number (A, B, C), the temperature range (commercial vs industrial), and the package type DIP, various different surface mount packages). These are often manufacturer specific.
For example, LM was created by National for their linear parts. TL was created by Texas Instruments for their linear parts. MC was used by Motorola for most of their parts. LT for Linear Technolgy, AD for Analog Devices. etc...
The CD4000 series was originally made by RCA and then licensed to other companies. Motorola sold them as MC14000 series. Toshiba used TC4000 series. TI and Fairchild stuck with RCA's CD naming. Philips did HEF.
widdly
PostPosted: Thu Aug 20, 2009 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is a U suffix to indicate Unbuffered. Certain circuits require unbuffered CMOS components. For example the TR-909 were the Cymbal, Ride and Hihat's require a CD4011UB. I recently repaired one with a non-working cymbal. It turned out someone had put a CD4011B in. I swapped it out for a CD4011UB and it worked fine. I think some of the distortion pedal circuits require a CD4049UB and the Wasp VCF requires a CD4069UB
LektroiD
PostPosted: Fri Aug 21, 2009 2:51 am    Post subject: Reply with quote  Mark this post and the followings unread
I have some 4011 ICs here made by RS components, they have no prefix or suffix, how would you know if they are buffered or not?
LektroiD
Clack
PostPosted: Fri Aug 21, 2009 12:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Its not really a fixed standard - depends on the company
best thing is to look at the datasheet of the source (Im sure there is one on the page you bought it from if its RS )
Clacktronics.co.uk
widdly
PostPosted: Tue Aug 25, 2009 12:23 am    Post subject: Reply with quote  Mark this post and the followings unread
They stopped making most of the unbuffered parts some time ago so they are harder to find. The 4069 and 4049 can be found but other unbuffered parts are quite rare now days.
