 Forum index » Instruments and Equipment » Nord stage
Nord Stage Ex - Control and Swell pedal volume problem
Page 1 of 1 [2 Posts]
kkness
PostPosted: Fri Aug 14, 2009 10:39 am    Post subject: Nord Stage Ex - Control and Swell pedal volume problem
Subject description: Problem with voluime cutting down when a pedal is plugged into the control and organswell plugs
I'm having an issue that just started that I cant figure out . I have a new stage ex 88 (4.04) . I've been using a yamaha fc7 expression pedal with it for organ swell. It has been working fine until recently . Now when I plug it in , the volume on the organ gets cut WAY down . When I unplug the pedal , it goes back to normal . This happens on both the control pedal and organ swell inputs. I've tried the pedal on my electro 2 , and it seems to work just fine . Anyone have any ideas on where to start with this issue ? I've looked thru the system setups, but I cant seem to see where the problem may be .
casi
PostPosted: Fri Aug 14, 2009 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Maybe try to define a different pedal in the setup-menu. If that doesn't help, simply switch back to the original and see if that does the trick.
If you have any other swell/volume pedals try them as well.
Ca2
