Inventor
Joined: Oct 13, 2007 Posts: 5948 Location: San Antonio, Tx, USA
Audio files: 256
Posted: Sun Sep 13, 2009 7:46 am Post subject:
Back-to-Back Nonpolarized Caps Subject description: How do they work? |
We all know about that trick of putting two electrolytic caps in series, with their negative terminals tied together. This makes a non-polarized cap of half the value. The quesion is: why does it work?
I've asked around in prior workplace(s) about this and nobody seems to know why it works, and why half the value. What's your guess?
Joined: Apr 03, 2004 Posts: 19596 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sun Sep 13, 2009 8:27 am Post subject:
Half the value is expected for two caps in series, but why it becomes unpolarized was never clear to me either. _________________ Jan |
DrJustice
Joined: Sep 13, 2004 Posts: 2005 Location: Morokulien
Posted: Sun Sep 13, 2009 7:09 pm Post subject:
The only real attempt at explaining this that I could find is in this discussion, 8th posting down :
"It *IS* OK to put two polarized caps back-to-back to make an AC
cap out of them. The reason is that there is a tiny bit more leakage
in the reverse biased cap. That leakage charges the "properly" biased
cap in the right direction to keep it happy when the current reverses.
Since the circuit is symetrical, each cap's leakage protects the
other.
Do a test with real capacitors (or even a SPICE simulation). You
will find that after only a couple of cycles that each cap will have a
DC voltage across it that is of a magnitude and polarity such that it
will be completely protected from reverse voltages."
Better read the following messages too.
BTW, both common + or - will work.
BTW(2), if it's for audio decoupling, designers commonly use a single electrolytic cap and get away with it even in expensive eqiupment. This has never seemed quite right to me...
DJ
Joined: Jul 11, 2005 Posts: 4737 Location: Nambucca Heads, Australia
Audio files: 51
Posted: Sun Sep 13, 2009 10:24 pm Post subject:
Nice bit of research DJ  _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Do you really want to lose yourself? |
daverj
Posted: Mon Sep 14, 2009 10:58 am Post subject:
My understanding was that this is reliable with tantalum caps only, but that with aluminum caps you need to put a bias resistor on the point where the positive nodes meet.
At least that's what I was told, many many moons ago. |
DrJustice
Posted: Mon Sep 14, 2009 12:15 pm Post subject:
Well, some say that tantalum caps should never be used in this application. However, e.g. Kemet mentions this a perfectly fine application in one of their applications notes. They also mention that they sell prepackaged back-to-back pairs of tantalum caps for convenience. The same goes for aluminium electrolyte caps. That's good enough for me... but I'd rather spend on some non polar, non electrolytic caps (e.g. polypropylene) for audio AC coupling to max out the quality.
DJ
