Nord Lead 1x problem
Page 1 of 1 [12 Posts]
idiot.radar
PostPosted: Sun Sep 13, 2009 5:21 pm    Post subject: Nord Lead 1x problem
Subject description: pitch/mod issues
Hi all!
Wondering if anyone has ever had an issue with in-operable modulation and pitch bend on a nord lead 1x?
I checked the sys. settings, and pitch bend range is at full. I also get no error on start up, which seems like what should happen according to the manual.
It's running 2.6 era firmware. Any help would be appreciated.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Sun Sep 13, 2009 9:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome idiot.radar
Did you already lifted the red hood?
For details see
http://electro-music.com/forum/post-211756.html#211756
and
http://electro-music.com/forum/post-211760.html#211760
Check the connection wires on the devices and boards.
It looks like the first steps
Wout
PS
What is a NordLead1X?
Is it a typo or a special edition?
idiot.radar
PostPosted: Mon Sep 14, 2009 12:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout,
yeah, I guess that formatting's a little weird. It's the original lead. I popped the hood and all the connections looked good. I also de-oxidized the wiring harnesses on both sides. All the solder points look good, and seems odd that it would be these 2. Intuition tells me a firmware issue, but I won't discount hardware yet...
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Sep 14, 2009 4:04 am    Post subject: Reply with quote  Mark this post and the followings unread
When booting what does the LCD reads out, in a flash... NL or NR?
Wout
doctorno
G2 patch files: 8
PostPosted: Fri Nov 12, 2010 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
I have got exactly the same problem with my Nord Lead 1. The connections of the pitch stick and modwheel are okay, pitch and modulation wheel functions work via MIDI but the pitch stick and modwheel on the NL1 do not do anything. On startup of the machine Er and then A is displayed.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Nov 12, 2010 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Are you sure it isn't [E] then [rA]?
In which case it means the synth thinks it's a Rack version...
[E] means 'expanded' and [rA] means 'rack'.
[Er] could be 'error' on [A]???
Wout
doctorno
G2 patch files: 8
PostPosted: Fri Nov 12, 2010 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout, yes, it´s "E" and then "rA". what does this mean? Has somebody put a Nord Rack board into my NL1 (I have just bought the unit used)?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Nov 12, 2010 9:50 am    Post subject: Reply with quote  Mark this post and the followings unread
The operating system can't find the wheel or the stick!
If the wires are okay, one of the units might be broken.
Anyway, it's a service station job. You can't do it yourself.
Wout
doctorno
G2 patch files: 8
PostPosted: Fri Nov 12, 2010 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, Wout. This does not sound very good to my ears. I am afraid that I will have to return the NL1 to the dealer, where I bought it. What a pity - it sounds so good.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Nov 12, 2010 11:01 am    Post subject: Reply with quote  Mark this post and the followings unread
It can be repaired. NordLead-1's aren't that easy to get now-a-days...
Wout
doctorno
G2 patch files: 8
PostPosted: Fri Nov 12, 2010 11:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Wout
I have seen many on ebay recently. Do you think that the NL1 sounds much different from the current NL2x?
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Fri Nov 12, 2010 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes!
Wout
Niio1
