  bingsatellites Mostly Ambient
 Forum index » How-tos » Micro Tuning
Scala support for older Ensoniq synths
sizone
Audio files: 48
PostPosted: Fri Sep 25, 2009 1:45 am    Post subject: Scala support for older Ensoniq synths
Subject description: TS, VFX
Working on getting Scala support for my TS-12 right now (figured it out without the sysex specs). If you want to help get other Ensoniq synths supported here's what you can do:
If you own a TS-10 or a VFX, edit the first user program (U0-0) so that the pitch table option is on. Edit the pitch table so that the first entry (A0) is set to coarse tuning C8 and the last entry ( C8 ) is set to coarse tuning A0 (the values are arbitrary, I just need to know where the tuning data begins and ends and those values make it easy). Set the device ID to 12 (again, arbitrary, but makes finding things easier), set the base channel to 11. Do a single program dump (current program, make sure you're on program U0-0) and send me a copy of the dump in plain .txt format. If you need help figuring out how to do any of this, let me know and I'll try to walk you through it. It would be nice to get dumps from as many of the VFX derivatives as possible as Ensoniq had a weird habit of slipping model specific flags into their sysex headers.
emSynth
