New module at yusynth.net : Quadrature VC-LFO
Page 1 of 3 [55 Posts]
Goto page: 1, 2, 3 Next
yusynth
PostPosted: Sat Oct 03, 2009 3:07 pm    Post subject: New module at yusynth.net : Quadrature VC-LFO Reply with quote  Mark this post and the followings unread
Title says it all, check it at http://yusynth.net/Modular/index_en.html
Yves
PostPosted: Sat Oct 03, 2009 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, that´s quite a useful little rascal you have there. Very Happy
Flickr
Sebo
PostPosted: Sat Oct 03, 2009 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wonderful Yves!!!
Another great module!!!
Thanks.
Sebo
My Music:
www.cosaquitosenglobo.com.ar
diablojoy
PostPosted: Mon Oct 05, 2009 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
another to add to the list Smile
Thalassa
PostPosted: Mon Oct 05, 2009 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Just one question...
On the wiring diagram there are two level pots , is it the same pot but just doubled wired ?
The bad thing about this module it's that I'm starting to full my cabinet and I want to build a lot of modules more Very Happy
Great work Yves
http://www.corsynth.com
yusynth
PostPosted: Mon Oct 05, 2009 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Great work Yves
There is a dual gang potentiometer (OUTPUT LEVEL): two coaxial pots sharing the same shaft. Like this :
http://www.musikding.de/product_info.php/info/p1628_Alpha-Potentiometer-24mm-Stereo-100k-lin.html
You started with a small size cabinet and you will end with a huge one just like I did ! :
http://yusynth.net/gear/studio/index_en.html
Yves
Thalassa
PostPosted: Mon Oct 05, 2009 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your fast reply Smile , Will be on my "things to do" list . By the way i also saw the modular synth that is selling on Ebay ( you make a comment on the matrixsynth ). I was cehcking the wesite also and at least the front panels are copies of your designs I think that they should said something that is based on your designs.
yusynth
PostPosted: Mon Oct 05, 2009 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
From what I saw on their site the PCB have been slightly redesigned : same drawing but spread over a large PCB.
I agree they could have mentioned that it is based on the yusynth design.
Yves
numbertalk
PostPosted: Tue Oct 06, 2009 4:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great news and a great looking module. Definitely going into my ever-growing queue.
Pehr
PostPosted: Thu Oct 08, 2009 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice looking module Yves! Very Happy small and tidy, great work!
but we want sound samples too! Wink
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
6079smith
PostPosted: Fri Oct 09, 2009 12:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Finished this last night, and it works just great. Thanks Yves!
A.
yusynth
PostPosted: Fri Oct 09, 2009 12:35 am    Post subject: Reply with quote  Mark this post and the followings unread
A.
Yes it is quite an easy project to build, it works straight away !
Have fun with it.
Yves
synthmonger
PostPosted: Tue Oct 13, 2009 5:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Yvves,
On your Quadrature LFO page you mention Shepard tone generation with 4 VCOs.
Is it as simple as sending the phase outputs to 4 VCOs that are octaves apart?
I believe you need two of the VCOs amplitude being controlled by a sawtooth oscillator that has 0 and 180 degree outputs. It would also need to run at twice the frequency. I assume you would need that kind of setup to make the transition between pitch smooth.
Youtube!
modular demos!
Whacky tunes!
yusynth
PostPosted: Tue Oct 13, 2009 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
synthmonger wrote:
Hi Yvves,
I gave a clue of a possible use of the Quad-VCLFO, then one has to dig things up by oneself.
With four sinewaves you have only one part of what is required for true shepard tone generation, but nevertheless one can already obtain some fun effects with the sinewaves only.
Yves
synthmonger
PostPosted: Wed Oct 14, 2009 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah! I wasn't sure if it was as easy as plugging them into 4 VCOs octaves apart. I did some googling then found out what you needed exactly and while it is simple you do need a lot more than what I originally thought.
Thanks for clarifying Yvves Wink
Youtube!
modular demos!
Whacky tunes!
numbertalk
PostPosted: Wed Oct 14, 2009 7:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Mind sharing a link(s) to what you found?
Thanks.
synthmonger
PostPosted: Wed Oct 14, 2009 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
http://www.youtube.com/results?search_query=shepard+tone&search_type=&aq=f
I did some "simulations" in ableton like the guy did in his youtube demos. It's fun to mess around with and get a feel for it. Though I barely know the program and it probably could've taken me less time to build it on breadboard then figure out in Ableton.
The links on Yusynth's page about the Quadra VCLFO also work.
Youtube!
modular demos!
Whacky tunes!
numbertalk
PostPosted: Wed Oct 14, 2009 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Awesome, thanks!
I did some "simulations" in ableton like the guy did in his video on Youtube. It's fun to mess around with and get a feel for it. Though I barely know the program and it probably could've taken me less time to build it on breadboard then figure out Ableton.
Sine
PostPosted: Sat Oct 17, 2009 12:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's tricky to do
I experimented a bit with my modular but the imprecision of the dual gang pots and the least bit of tracking errors in the VCO's ruins the effect.
yusynth
PostPosted: Tue Dec 08, 2009 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
UPDATE
I have corrected the wiring diagram where the connections of the dual gang pot were mixed up. Now it is fine Wink
Yves
klstay
PostPosted: Wed Apr 28, 2010 9:30 am    Post subject: PCB source Reply with quote  Mark this post and the followings unread
Has anyone done a run of PCBs for this? (Any bridechamber plans for PCBs and panels?)
yusynth
PostPosted: Wed Apr 28, 2010 11:40 pm    Post subject: Re: PCB source Reply with quote  Mark this post and the followings unread
Scott Deyo did not express interest for this module, I will ask him if he is interested.
Yves
littlem4tt
PostPosted: Fri Sep 06, 2013 4:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you confirm if there a 3 or 4 wire links in the design?. There are 4 in the diagram but the text says 3
littlem4tt
PostPosted: Fri Sep 06, 2013 6:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I have connected all 4 and all is good.
I have adapted the original design for eurorack 12v. (no modifications!)
Because the board is so long i used photoshop to cut the design in half and placed each half next to each other. And then re connected the breaks.
I also added solder pads for the pots so i could mount the board easily.
Thank you so much Yves for sharing. This is my second yusynth module and i have already made a clock divider pcb. Very Happy
[/img]
 Filesize:  120.13 KB
 Viewed:  294 Time(s)
 Filesize:  680.04 KB
 Viewed:  297 Time(s)
 Filesize:  139.36 KB
 Viewed:  299 Time(s)
yusynth
PostPosted: Fri Sep 06, 2013 7:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice eurorack adaptation Cool
Yves
