ref/part numbers for 3 non ceramic caps in resonator module
Page 1 of 1 [3 Posts]
bennethos
PostPosted: Sat Oct 31, 2009 1:36 am    Post subject: ref/part numbers for 3 non ceramic caps in resonator module Reply with quote  Mark this post and the followings unread
Hi all,
I'm building the resonator and am wondering if anyone has part numbers for those 3 non ceramic caps. I can't find the biggest value in polystyrene :-/ ...
thx
magman
PostPosted: Sat Oct 31, 2009 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Benethos,
First, I don't think you have to worry about using polystyrene caps for these components, you can use Polyester or Polycarbonate. If you look at Dave Brown's website, it looks like Dave has used Polyester Film caps.
For a Polyester cap, you could try any one of these: Farnell Capacitors
If you want to stick with Polystyrene caps though, I've found another site on the web that may be able to help:
http://www.rush-on-line.co.uk/cap_forums.html
This site appears to have a very good stock of Polystyrene capacitors at very good prices. For example, they have a 68nF 63V Polystyrene cap for just £0.49.
I must admit though, that I've not bought anything from them as yet, so I don't know what their service is like.
Hope this helps, good luck on hunting down the right components and getting this module built.
Regards
Magman
bennethos
PostPosted: Sat Oct 31, 2009 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
thx for the tips, i'll work it out Smile
Niio1
