brother303
Joined: Nov 02, 2010 Posts: 139 Location: ruhr-area/germany
Posted: Tue Nov 02, 2010 2:43 am Post subject:
Hi Fonik,
hey,first post...
I´m a few wires away from finishing my sequencer,but there is one question.
In your building instructions there are 2 cv-outs. One on W1 (processed cv-out) and one on the gate/trigger/cv-jumper.
What`s the difference between those two outs? Is the processed-cv out on W1 only an optional thing?
Thanks for this cool project and best regards
Greg |
Posted: Tue Nov 02, 2010 2:57 am Post subject:
| brother303 wrote: | Hi Fonik,
hey,first post...
Greg |
hi greg,
the CV on th the W1 pad is optional. it is just the output of the CV processor in front of the ADC.
it might be that you don't use the sequencer, or you use it without the ADC, but with the switches only. then you could still use the CV conditioner/processor for other tasks independently (attenuation, adding offset) from W1.
hope that helps. _________________
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
brother303
Posted: Tue Nov 02, 2010 3:21 am Post subject:
| fonik wrote: | | hope that helps. |
Yes,it did!
Thanks for support.
Regards
Greg
LektroiD
Joined: Aug 23, 2008 Posts: 960 Location: Scottish Borders
Posted: Wed Nov 17, 2010 11:53 am Post subject:
Hi, what type of caps are recommended for the 100nF? Obviously I'd rather go through my ceramics before eating into my collection of audio grade caps  _________________ My tunes available here
(check out the new Electro-Funk LP) |
LektroiD
Posted: Wed Nov 17, 2010 2:07 pm Post subject:
| fonik wrote: | | i always use just ceramic for these decoupling caps. |
are all 21 decoupling caps, or should certain ones be higher grade? _________________ My tunes available here
Joined: Jan 07, 2009 Posts: 606 Location: Scottish Borders
Audio files: 69
Posted: Wed Nov 17, 2010 5:18 pm Post subject:
To the left hand side of the 2 circuit diagrams on the documentation of the vcps-8 , there are some layouts of caps only with i/c numbers & relevant power rail , these caps denote decoupling & power clean up duties, all the caps you see there are fine with ceramic multi-layer or yv5 rough tollerance caps & where showen electrolytics , caps of the same value that are showen in the actual device circuit diagram should been better tollerance like polyester / mylar / etc.
What i do is , mark off with a flourescent marker pen those clean up caps as i put them in first , once the decouple's are all done the remainder of that value (if any) would be polyester box caps. _________________ www.myspace.com/skrogproductions |
oldmanfury
Adam-V
Posted: Mon Dec 06, 2010 4:02 pm Post subject:
Are boards for this still available Matthias?
Adam-V _________________ Digitalis Effect | Fractured Symmetry (www.spiralsect.com) |
Adam-V
Posted: Mon Dec 06, 2010 4:18 pm Post subject:
Brilliant, I'll take 2 please.
I'll continue this via PM.
Adam-V. _________________ Digitalis Effect | Fractured Symmetry (www.spiralsect.com) |
Rvlt
Posted: Mon Dec 20, 2010 7:57 pm Post subject:
Subject description: another batch? spare pcb? |
hi everyone,
it seems that all pcbs are sold by now , so if there will be another batch in the near future i would take one (or two)
OR
(just in case): if anyone has a spare pcb to sell, please pm me. i would definitely buy it.
ok, best regards,
lars |
TekniK
djg
Posted: Tue Jan 11, 2011 12:02 pm Post subject:
| To clear up some confusion, when using an LM324 for the buffers, if the RA resistors are changed to 10K, would any change be needed for the RB values? |
Posted: Wed Jan 12, 2011 12:09 am Post subject:
| djg wrote: | | To clear up some confusion, when using an LM324 for the buffers, if the RA resistors are changed to 10K, would any change be needed for the RB values? |
no. the changed ratio of RA/RB sets the gain.
according BOM the RA resistors are 20k, the RB resistors are 10k. this would give you a gain of 1+(20/10)=3. since the ADC delivers 5V you will have a range of 15max. however, a TL074 wii not go that high. it will stop at 12.5V when powered by 15V. using a LM324 would help then, due to the fact that this opamp swings almost to the rails.
so if you use 10k for the RA resistors a TL074 is sufficient.
for a range of 5V you would simply leave off the RB resistors and use a bridge for the RA resistors...
in other words: decide wich output range you prefer (i set mine as high as possible and use an attenuator at the output instead), and then choose the opamp. _________________
fonitronik at
arnoid
Posted: Thu Jan 27, 2011 3:48 am Post subject:
two fellows have had some issues when using certain PSUs. the ADC won't start conversion sometimes, when powering up the module.
here is a little "ignition system"-circuit, that should help. it is a automatic start switch for the ADC, and seems to work fine (however, i had no opportunity to test it with my units, since they start and run quite fine).
explanation: the rising edge from the 5V rail when powering up the module is converted to a short pulse. the pulse controls a transistor to momentarily short pins 3 & 5 of the ADC to GND.
i will incorporate this info in the documentation soon. _________________
fonitronik at
patchdub
Posted: Sat Jan 29, 2011 2:10 am Post subject:
hi folks! i'm about to make a mouse order but i can't find the 7805 or 100uf. anybody know the numbers for these? that would be much appreciated!
thanks! _________________ www.patchdub.com |
Posted: Sat Jan 29, 2011 7:19 am Post subject:
| patchdub wrote: | hi folks! i'm about to make a mouse order but i can't find the 7805 or 100uf. anybody know the numbers for these? that would be much appreciated!
thanks! |
512-LM7805CT
647-UVR1J101MPD1TD _________________
fonitronik at
patchdub
Posted: Sat Jan 29, 2011 11:37 am Post subject:
thanks matthias!
the 512-LM7805CT is on backorder will the LM78L05ACZXA work? _________________ www.patchdub.com |
patchdub
Posted: Sat Jan 29, 2011 2:46 pm Post subject:
thanks! excellent build! _________________ www.patchdub.com |
emdot_ambient
Joined: Nov 22, 2009 Posts: 669 Location: Frederick, MD
patchdub
Posted: Sun Mar 27, 2011 9:13 am Post subject:
| emdot_ambient wrote: | Nowhere close to actually completing the build on this, but I think I've finalized my design.
2U high 19" wide panel, includes the Barton Music Circuits Simple Quantizer.
that will look sweet next to your m-185 panel! _________________ www.patchdub.com |
