Looking for a Klee Builder
Page 1 of 1 [15 Posts]
emergencyofstate
PostPosted: Tue Nov 10, 2009 11:18 am    Post subject: Looking for a Klee Builder Reply with quote  Mark this post and the followings unread
Hi all! I frequent the muff wiggler forum but I figured elctro-music would be a wise place to post this request.
I'm purchasing a klee kit from a fellow muff wiggler forum member (seen here > http://www.muffwiggler.com/forum/topic-9612.html)
I need someone to build for me. I can provide references if needed. Thanks!!
Very Happy Very Happy Very Happy
neandrewthal
PostPosted: Tue Nov 10, 2009 10:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you seen droolmasters post on this topic over at muffs? I can't remember the name of the builder dude.
sduck
PostPosted: Wed Nov 11, 2009 8:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't worry, I sent him a name
Audio files: 22
PostPosted: Mon Dec 14, 2009 10:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Any resolution here ? .... Perhaps I can help ??? PM with your needs. Maybe an arrangement can be worked out.
Bill
sMs Audio Electronics
jachinboaz
PostPosted: Sun Jan 30, 2011 11:39 am    Post subject: Re: Looking for a Klee Builder Reply with quote  Mark this post and the followings unread
can anyone post the links to the Klee thread on Muffwigglers ? and if anyone fancies posting info on possible builders please do - looking to have one built myself.Feel free to mail me direct also.
Very Happy Very Happy Very Happy[/quote]
Audio files: 22
PostPosted: Sun Jan 30, 2011 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have built 3 of these for folks. The panel I utilize of the One from Bridechamber which is a MOTM form factor. The pictures are a sample of two I built for a client in the Midwest. PM your needs and maybe we can strike a deal. I have references for my work as well.
Bill
 Filesize:  2.41 MB
 Viewed:  133 Time(s)
 Filesize:  1.64 MB
 Viewed:  140 Time(s)
loydb
PostPosted: Sun Jan 30, 2011 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice build!
KEYKEYEYEKIT
PostPosted: Wed Feb 09, 2011 7:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
What is the third board in your build?
Audio files: 22
PostPosted: Thu Feb 10, 2011 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
The third board is a feature to add a synchronous manual load function. Normally when you press the MANUAL LOAD pushbutton, the pattern loads immediately, asynchronously to any incoming clock. This circuit adds the option to manually load a pattern synchronous with the CLOCK input.
Bill
KEYKEYEYEKIT
PostPosted: Thu Feb 10, 2011 10:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
That sounds fun. Did you get the boards made? I can't seem to find anything on EM. Would this be something easily breadboarded? Like to give it a shot. Also, your wiring is amazing. Shocked
Audio files: 22
PostPosted: Fri Feb 11, 2011 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks !! Wink I have attached a document that I wrote explaining the mod in detail. I have also attached the HEX file for the small PIC chip.
If you don;t have a means of programming the IC, I can send you one if you would like to try the mod for yourself.
Bill
sync_load_mod_description.pdf
 Filename:  sync_load_mod_description.pdf
 Filesize:  5.06 MB
 Downloaded:  148 Time(s)
SyncLoad.HEX
 Filename:  SyncLoad.HEX
 Filesize:  677 Bytes
 Downloaded:  126 Time(s)
KEYKEYEYEKIT
PostPosted: Tue Feb 15, 2011 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Bill! I will add this to the pile Embarassed of projects.
sneakthief
PostPosted: Tue Feb 15, 2011 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Why not attach an optical or mechanical relay in series with the load button and trigger it by a pulse from clock-divided signal? That way it could load every 2nd, 3rd, 4th, etc. division of the clock?
Sneak-Thief - raw electrofunk
marmad
PostPosted: Tue Apr 12, 2011 6:20 am    Post subject: Reply with quote  Mark this post and the followings unread
What is strange is that the topic - "Add a Synchronous Manual Load to the Klee" - has been deleted from the forum. In that thread, Bill explained how his synchronous load mod worked, and I posted another possible method of doing it using one chip of discrete logic (CD4053) - less complex (or programmable) than Bill's - but more modding intensive.
Since it's gone, I'll post it again now - including the altered schematic and photos of the added circuitry, the modded digital board, and the added toggle (and LEDs) on the front panel.
Mark
Changed schematic for synchronous load.
 Filesize:  90.67 KB
 Viewed:  138 Time(s)
Daughterboard that plugs into U5 socket.
 Filesize:  3.57 MB
 Viewed:  106 Time(s)
Klee digital board w/daughterboard plugged-in.
 Filesize:  4.59 MB
 Viewed:  111 Time(s)
Extra toggle on front panel for Sync/Async loading with bi-color LED indicator.
 Filesize:  3.71 MB
 Viewed:  109 Time(s)
DaLuke
PostPosted: Tue Nov 15, 2011 6:33 am    Post subject: Klee Sequencer
Subject description: building the sequencer
Bill
I would like to have one of these sequencers built by someone...I have the 2 boards but that is all, please let me know if you will...I will send the money for parts, etc.
View user's profile Send private message Yahoo Messenger
Niio1
