 Forum index » DIY Hardware and Software » Rob Hordijk DIY Designs
Powerswitch for a battery powered Benjolin
Post new topic   Reply to topic Moderators: Rob
Rob
G2 patch files: 109
PostPosted: Tue Nov 17, 2009 4:57 am    Post subject: Powerswitch for a battery powered Benjolin Reply with quote  Mark this post and the followings unread
You can use a double pole toggle switch to switch your Benjolin on/off.
Connect one pole of the switch at the left of the four battery conncetion points and the other pole at the right of the four points.
 Filesize:  46.53 KB
 Viewed:  2145 Time(s)
Niio1
