oscilloclast
Posted: Wed Nov 25, 2009 2:54 pm Post subject:
Benjolin Osc problem Subject description: Benjolin Osc problem |
Rob,
The output of Osc 2 is a downward sloping ramp (it should be a triangle) and a very weak pulse (it should be stronger like the pulse out on Osc 1). Any suggestions on where the problem may be? All of my IC's have sockets and I have replacements for all of them (if I need to switch them).
Thanks,
David |
Audio files: 22
Posted: Fri Dec 04, 2009 2:15 pm Post subject:
As is the case most of the time, bad IC's are usually not the casue of a problem but more a wrong value component surrounding them. Try the simple thing and check the components in each oscillator one for one as they are identical circuits .. for example ..... R12 and R5, R6 and R13 ... ect ....
Also, check for "bent under" pins on IC2, 6, and 3 ....
After you check that these components are correct .... then check for solder bridges around these components to make sure they are ONLY connected to where there supposed to be. ... if thats good .. then ......
on U3 pins 5 and 2 .. with power OFF, check that they are connected together and to ground. This is the reference to the output amplifier that creates the pulse , P2 ....
Lets try these things first ....
Bill |
oscilloclast
Posted: Sat Dec 05, 2009 9:17 am Post subject:
Bill,
Thanks for the tips. I actually replaced all of the chips (I used sockets when I built it) but the problem turned out to be some switched resistors. The output waves are correct now but I'm getting +/- 5v on bth triangles and +/- 10v on both pulse (so I need to look into this descrepency).
Thanks,
David |
Audio files: 22
Posted: Sat Dec 05, 2009 5:33 pm Post subject:
Good news ... BTW, the pulse will be larger in amplitude than the triangle waves so there is nothing wrong. The TRI waveforms feed an approximately 9 dB amplifier stage so that is OK ...
The pulse output is feed back via the 100K resistor (R3/R10) into the OTA to reverse the current into the integrator ...
With a split 9V supply (+9V/-9V), you would not get any more then 18V P-P ideally but the TL074 does not go to the rail so it;s something less. I say this because you mentioned that you had +10/-10 and that equates to 20V P-P, unless I misunderstood what you said??
Bill |
oscilloclast
Posted: Sun Dec 06, 2009 9:15 pm Post subject:
Yep your right, I should have said +/- 8v.
Thanks,
David |
