joggle
Posted: Mon Dec 07, 2009 3:49 pm Post subject:
Nord midi output again |
Good evening,
I have a (noobish) Question. As far as I understood the NM can only send out the CC of his own Knobs. But is there a way to send out the note´s which my rack recieves via midi in? Or in other words what comes out the Midi out? 1. Clock 2. Knob CC 3.. anything else?
thanx for your attention and please forgive me my bad english..
Greetings |
egw
Joined: Feb 01, 2003 Posts: 1569 Location: Asheville NC
G2 patch files: 8
Posted: Tue Dec 08, 2009 7:23 am Post subject:
Midi Out only includes data generated by the instrument. To send incoming notes (or other incoming midi data) out, you need a midi Thru port. This applies to most all midi devices, except some sequencers or devices that have a built-in "merge" function. You can do what you want with an external midi merger or thru box, depending on your configuration. _________________ www.gregwaltzer.com |
joggle
Posted: Tue Dec 08, 2009 10:41 am Post subject:
Okay. But I can assign a CC value and a knob to a parameter, so when I now change the CC value it will be transmitted via midi out, won´t it? And that means If I have an extra slot free, I could design a patch to let 18 Midi CC "thru the synth" ( and I don´t have to pay 30 euro for a Mergebox)?
thanks or the answer and may coming answers. |
Moody33
G2 patch files: 16
Posted: Tue Dec 08, 2009 11:29 am Post subject:
| Open a slot, put 18 "constant level" each one assign to the same CC# as your external midi controllers. Should work. |
Joined: Feb 04, 2005 Posts: 2872 Location: Nottingham, UK
Audio files: 279
Posted: Tue Dec 08, 2009 2:33 pm Post subject:
If you want to merge note information from another synth with controllers generated by the nord modular you will need a midi merger to merge the out with the thru _________________ Jez
music | adventures in sound | gear for sale |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed Dec 09, 2009 1:16 am Post subject:
| Moody33 wrote: | | Open a slot, put 18 "constant level" each one assign to the same CC# as your external midi controllers. Should work. | Have you tried it? It's the Knob which generates MidiOut, not the Midi In.
Wout |
Moody33
G2 patch files: 16
Posted: Wed Dec 09, 2009 8:58 am Post subject:
I'm sure it works. I've already use this feature with my DAW. It's logical : this is a feature for those who used external sequencer. So if you want to record NM knob mouvement in your DAW , you also need the possibility to send those mouvement to the NM itself when you push PLAY...
Sorry for my bad english. |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Wed Dec 09, 2009 11:06 am Post subject:
Sure, but that's not what joggle wants to do, I think. As I understand from this | Quote: | | But I can assign a CC value and a knob to a parameter, so when I now change the CC value | That is not the knob! | Quote: | | it will be transmitted via midi out, won´t it? | joggle expects the CC to change the knob too, not only the parameter. If so, he could use the CC Midi out to be used as a Midi Through set up.
Only the knob isn't controlled by the incoming Midi CC, only the parameter is. And the knob is the one who sends the CC out...
In short: the knob can control the Midi CC, but the Midi CC can't control the knob. Both can control the parameter.
Wout
PS The NordLead 3 can and the G2 (That one can do even much more), but both have a Midi Through already  |
joggle
Posted: Thu Dec 10, 2009 2:57 pm Post subject:
Good evening,
Wout gets the point. Thanks for all the answers. So i have to buy a Midi Mergebox...
Lg joggle |
