gomidas
Joined: Jul 09, 2004 Posts: 365 Location: La Ciotat, France
G2 patch files: 6
Posted: Thu Dec 17, 2009 1:51 am Post subject:
.pch2 to .syx conversion |
Hi everybody
Is there a way ton convert .pch2 to .syx without the editor?
Thanks |
Wout Blommers
Audio files: 123
G2 patch files: 12
Posted: Thu Dec 17, 2009 7:55 am Post subject:
I think it is sysex...
Wout |
Audio files: 278
gomidas
G2 patch files: 6
Posted: Thu Dec 17, 2009 5:21 pm Post subject:
Thanks Guys,
it's always nice to hear from you
Changing the extension won't do the trick...i'll try some other stuff later...
Thank you |
Audio files: 278
Posted: Thu Dec 17, 2009 5:51 pm Post subject:
Sorry ... didn't find time tonight to sort this out ... and no, extension changing indeed won't do ... the data needs to be reformatted a bit ... i did write a program to do just that, but will need to search for it ... I will come back on this, promise! _________________ Jan
cappy2112
Joined: Dec 24, 2004 Posts: 2465 Location: San Jose, California
Posted: Thu Dec 17, 2009 11:17 pm Post subject:
Blue Hell wrote: | Sorry ... didn't find time tonight to sort this out ... and no, extension changing indeed won't do ... the data needs to be reformatted a bit ... i did write a program to do just that, but will need to search for it ... I will come back on this, promise! |
Got source? _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
gomidas
G2 patch files: 6
Posted: Fri Dec 18, 2009 8:13 am Post subject:
Hey! Blue Hell! Thanks for your help!!!!
As you must know, my two G2 Engines do have broken USB circuits, so no Editor for me until the repair (I must change the two motherboards, it's gonna cost me some money but I am going to do it).
With sysex I wil be able to load nice patches inside my nords and work like that, MIDI Progam Changes are messy to work with sequencer anyway, sometimes they launch when you start your project(Protools, Live8) and sometimes not, also when you loop a clip(live) or a region(Protools) and the PC is inside that clip, the G2 will reload the patch...
I will also convert my patches to use them but I didn't make the MIDI CC# assignement on all of them, that make some sound kind of useless(what become a synth sound if you cannot tweak is parameter in real time?)
So as a special request.., please don't forget to mention your midi cc# assignement in your Patch Info (I can also send a midi cc request from a BCR2000, but Info will be quicker)
Thanks |
Audio files: 278
Posted: Fri Dec 18, 2009 11:35 am Post subject:
I found pch2midi on my harddisk ... a windows program ... I did not test test it and it does have the Delphi source code ... if it don't work I'll look into it ... it wants to save the midi files as .bin files, but you can rename it to whatever seems best, its just a raw MIDI file ...
License blurb :
Code: | // ////////////////////////////////////////////////////////////////////////////
// Copyright (C) 2006 Jan Punter
// This program is free software; you can redistribute it and/or modify
// it under the terms of the GNU General Public License as published by
// the Free Software Foundation; either version 2 of the License, or
// (at your option) any later version.
// This program is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
// GNU General Public License for more details.
// You should have received a copy of the GNU General Public License
// along with this program; if not, write to the Free Software
// Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
// lupd : 2006-03-25
Description: |
A pch2 (and prf2) to midi translator for G2 patch files |
Download |
Filename: |
pch2midi.zip |
Filesize: |
263.17 KB |
Downloaded: |
772 Time(s) |
gomidas
G2 patch files: 6
Posted: Fri Dec 18, 2009 1:00 pm Post subject:
P.E.R.F.E.C.T !!!!!!
It works with crossover on mac too, I will use it as a command line for big folders.
Blue Hell, THANK YOU VERY VERY MUCH!!!! You are the Man
See you
Michaël |
Audio files: 278
Posted: Fri Dec 18, 2009 1:33 pm Post subject:
Wow it actually works & all? you tested that? _________________ Jan
gomidas
G2 patch files: 6
Posted: Fri Dec 18, 2009 5:50 pm Post subject:
Blue Hell wrote: | Wow it actually works & all? you tested that? |
YES 101% working! |
Audio files: 278
Posted: Fri Dec 18, 2009 6:02 pm Post subject:
Wow, good to hear! _________________ Jan
3phase
G2 patch files: 141
Posted: Wed Jan 20, 2010 4:31 pm Post subject:
is the g2 able to recive patches via sys ex? |
Akum420
G2 patch files: 11
Posted: Wed Jan 20, 2010 9:45 pm Post subject:
It's not working for all patchs for me ....85% working lol |
Audio files: 278
Posted: Thu Jan 21, 2010 10:10 am Post subject:
3phase wrote: | is the g2 able to recive patches via sys ex? |
Yes. _________________ Jan
Audio files: 278
Posted: Thu Jan 21, 2010 10:11 am Post subject:
Akum420 wrote: | It's not working for all patchs for me ....85% working lol |
Could you post a non working patch? or did you mean that the sysex transfers do not always work? _________________ Jan
Akum420
G2 patch files: 11
Posted: Thu Jan 21, 2010 6:45 pm Post subject:
I think it was a patch from the G1/NordLead converted to the G2 (.pch to .pch2). I check this tonight. |
Akum420
G2 patch files: 11
Audio files: 278
Posted: Fri Jan 22, 2010 8:11 am Post subject:
Textpad ... right ... that doesnt get stripped I guess while it should. Will have a look later ... _________________ Jan
varice
Joined: Dec 29, 2004 Posts: 961 Location: Northeastern shore of Toledo Bend
Audio files: 29
G2 patch files: 54
Posted: Fri Jan 22, 2010 11:59 am Post subject:
Akum420 wrote: | Look at this one. I found what's the problem.
Only some characters in the textpad. It's probably easy to solve in the delphi source code. Btw, it's not a big problem. |
I think the problem may be with the patch file generated by the g1 to g2 convertor - the 1.5 version is known to have some conversion bugs...
I loaded the posted problem example patch into the 1.40 Editor (not connected to a G2) then saved it back to disk. Comparing the two shows many differences, even the byte counts are different.
I would suggest that you try loading and saving the patch with the Editor and then try the pch2midi conversion on the new Editor generated patch. _________________ varice |
Audio files: 278
Posted: Fri Jan 22, 2010 2:23 pm Post subject:
Ah, thanks for sorting that out Varice! _________________ Jan
varice
Audio files: 29
G2 patch files: 54
Posted: Fri Jan 22, 2010 2:38 pm Post subject:
Blue Hell wrote: | Ah, thanks for sorting that out Varice! |
No problem.
I forgot to mention that the problem patch does load and appear to work just fine in the 1.40 G2 Demo.
I would test the new patch converted with pch2midi but my MIDI enabled computer is not connected to my G2X at the moment... _________________ varice |
Akum420
G2 patch files: 11
varice
Audio files: 29
G2 patch files: 54
Posted: Fri Jan 22, 2010 11:00 pm Post subject:
Akum420 wrote: | The problem is the character in the red circle. |
Strange... I do not see those characters in the textpad when I open the problem patch with my 1.40 G2 Editor or Demo on my Windows XP computer. Maybe a Windows option setting different on my computer than yours?
Can you confirm that you only see these characters with patches that are generated with the G1 to G2 patch converter? _________________ varice |
Akum420
G2 patch files: 11
Posted: Fri Jan 22, 2010 11:14 pm Post subject:
not exactly, I only see it with the NL to G1 to G2.
Edit : and with the G1 ModularEditor3_03 if I look the .pch before to be converted to .pch2, everything is ok, no weird characters |
