replacing small speaker with 1/4" line out
Page 1 of 1 [9 Posts]
rungsglas
PostPosted: Mon Jan 04, 2010 8:16 pm    Post subject:  replacing small speaker with 1/4" line out Reply with quote  Mark this post and the followings unread
I am circuit-bending small kids toys and would like to replace the speaker with a 1/4" line out to plug into my recording equipment. Is it as simple as cutting the wires to the speaker and replacing them with the audio jack?
rungsglas
PostPosted: Mon Jan 04, 2010 8:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
idiot!
http://www.circuitbenders.co.uk/tips2.html
electri-fire
G2 patch files: 4
PostPosted: Tue Jan 05, 2010 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
rungsglas wrote:
idiot!
Hey rungsglas, don't be so harsh on our new member rungsglas! Little impulsive me has been guilty of being stunned by problems, asking things that could have easilly been answered with some Googling.
Well, ermm... welcome to electro-music.com.
Audio files: 278
PostPosted: Tue Jan 05, 2010 11:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked Laughing
welcome rungsglas
electri-fire
G2 patch files: 4
PostPosted: Tue Jan 05, 2010 11:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Also search in the archives of:
http://groups.yahoo.com/group/bendersanonymous/
http://groups.yahoo.com/group/benders/
Danno Gee Ray
PostPosted: Tue Jan 05, 2010 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome...to the club Wink
imaguitargod
PostPosted: Tue Jan 05, 2010 9:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome dude! To answer your question harshly, I'll say, "Why haven't you just opened your third eye to the universe and downloaded the info directly from the ether yet? You fool!"
To answer your question in a welcoming manor I would say, "Yes, it is that easy........sometimes. Sometimes the voltage is not that nifty and you might have to throw a specific "voltage divider" inline. For more on that be sure to check out this link: http://fluxplayshop.blogspot.com/2008/07/voltage-dividers.html."
Hope this helps Wink
Assistant brewer for Hoppin' Frog Brewery
My Noise Project: I Like Pie (MySpace Page)
electri-fire
G2 patch files: 4
PostPosted: Wed Jan 06, 2010 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
You nitwit! Laughing
Didn't you see this schematic: http://www.circuitbenders.co.uk/tips2.html IS a voltage divider?
This http://fluxplayshop.blogspot.com/2008/07/voltage-dividers.html uses higher value resistors, but as the ratio between them (10:1) is the same as in the circuitbenders schematic it outputs the same voltage, but has less current available (no problem, you don't need that).
The circuit expects an 8 ohm speaker, so the 10K-1K already reduces current a lot, the fluxplayshop scheme would be 10-fold easier still on battery drainage.
Both will work. Using a potmeter has the advantage of on board volume control , and to have the extra juice available when you WANT to drive the sound into distortion.
imaguitargod
PostPosted: Wed Jan 06, 2010 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
It was a late night lastnight and I didn't check out his link Wink
