Jackout
Posted: Tue Jan 05, 2010 4:10 am Post subject:
Blofeld sample playback question |
There doesn't seem to be a great deal of info around on the Blofeld's sample playback capabilities, can anyone enlighten me as to how it currently works? i.e:
- can you play your samples polyphonically?
- To what extent can you modulate your samples? Can you put them through everything that a normal Osc goes through?
- Is there any destruction in audio quality?
Cheers! _________________ Today is the future you were thinking about last year. |
musikmachine
Posted: Wed Jan 06, 2010 1:11 am Post subject:
Re: Blofeld sample playback question |
| Jackout wrote: | Hi,
- can you play your samples polyphonically? |
Yes you can. Samples are treated exactly the same as the oscillators.
| Jackout wrote: | | - To what extent can you modulate your samples? Can you put them through everything that a normal Osc goes through? |
See above.
| Jackout wrote: | - Is there any destruction in audio quality?
Cheers! |
Not unless you want there to be.
The sample option is a nice addon to the blofeld. You can load anything from oneshots to multisamples. The downside is you have to reload the samples each time; you can't add to an existing set and it takes time. I think to load 60mb would take 30 minutes. It's not that bad in practise but i usually work with smaller sets anyway. |
Keysandslots
Joined: Aug 18, 2006 Posts: 262 Location: Mississauga, Ontario
Posted: Wed Jan 06, 2010 6:11 am Post subject:
"The downside is you have to reload the samples each time; you can't add to an existing set and it takes time. I think to load 60mb would take 30 minutes. It's not that bad in practise but i usually work with smaller sets anyway."
Can you clarify this a bit? Do mean, every time you turn the synth on you need to re-load the samples?
Thanks
Randy _________________ 1974 (maybe 1975) Rhodes Stage 88, Kurzweil K2600XS, Kurzweil K2500R, Roland A35, Roland A90EX, Korg Microstation, Korg MicroKorg, Alesis SR-16, Shruthi SMR4 mk1, Shruthi 4PM, PreenFM, MIDIPal, iPad 2 + Alesis IO Dock, Maxon Phaser, Maxon Chorus |
musikmachine
Posted: Thu Jan 07, 2010 1:34 am Post subject:
| Keysandslots wrote: | "The downside is you have to reload the samples each time; you can't add to an existing set and it takes time. I think to load 60mb would take 30 minutes. It's not that bad in practise but i usually work with smaller sets anyway."
Thanks
Randy |
No i mean transmitting the samples from Spectre. It takes a few minutes to transmit samples to the blofeld. Spectre gives you an estimate of how long to will take as well but it usually is a bit quicker. You can try out the spectre software and even create your own programs and save them.  |
Keysandslots
Posted: Thu Jan 07, 2010 6:43 am Post subject:
Thanks for the clarification. I've been considering what to get next, and the Blofeld is at the top of my list.
Jackout
Posted: Thu Jan 14, 2010 5:29 am Post subject:
So what then can the Nord Wave do in terms of sample processing that the Blofeld cannot?
I cannot figure out how the Blofeld seems to offer all it does for so much less £ than other VAs. _________________ Today is the future you were thinking about last year. |
Muied Lumens
Joined: Apr 24, 2009 Posts: 1337 Location: Bristol UK
Audio files: 209
Posted: Thu Jan 14, 2010 5:51 am Post subject:
| Jackout wrote: | So what then can the Nord Wave do in terms of sample processing that the Blofeld cannot?
I cannot figure out how the Blofeld seems to offer all it does for so much less £ than other VAs. |
Good question. Basically, with the wave, the knobs add to the cost a lot, as does other hardware issues. The blofeld has some corners cut in the hardware department, even though it's a fantastic sounding synth with lots of control. Take a look at the guts of the blofeld:
http://3.bp.blogspot.com/_rScBRKlTdoE/S04q20ZjJUI/AAAAAAAAs3g/UUPFBU0KXUo/s1600-h/BLOFELD_17-SM.jpg
and
http://4.bp.blogspot.com/_rScBRKlTdoE/S04q2pNFuxI/AAAAAAAAs3Y/8lk3ZN8lybQ/s1600/BLOFELD_21-SM.jpg
I wouldn't buy a blofeld quite yet, because it still has a few issues in the software to sort out. As I have understood it, there is no proper multi-timbral mode, and there are a few other quite serious issues to sort out too. However, a new os version seems to be in the works so it will hopefully not be too long now.... _________________ robsol
Muied Lumens Base Star |
Jackout
Posted: Thu Jan 14, 2010 12:46 pm Post subject:
Cheers Muied. NAMM started today and Waldorf are there so it'll be interesting to see if they show any new developments. _________________ Today is the future you were thinking about last year. |
