Finished: Sawanimator
Page 1 of 1 [3 Posts]
Sebo
PostPosted: Sun Jan 10, 2010 3:16 pm    Post subject: Finished: Sawanimator Reply with quote  Mark this post and the followings unread
I finally finished the Sawanimator module, it is amazing.
I added the switch to join the 2 processed saws and the non processed one
in one output as Yves described in another thread.
Thanks Yves again.
Here are some pictures:
Sawanimator Front
 Filesize:  109.77 KB
 Viewed:  102 Time(s)
Sawanimator Back
 Filesize:  102.68 KB
 Viewed:  106 Time(s)
Sebo
My Music:
www.cosaquitosenglobo.com.ar
yusynth
PostPosted: Mon Jan 11, 2010 8:17 am    Post subject: Reply with quote  Mark this post and the followings unread
That's an interesting way of extending the board, gluing it at one end !... What I had in mind and did on my saw animator was to screw the add-on board above the main pcb using 20mm spacers
Yves
Sebo
PostPosted: Mon Jan 11, 2010 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, at the beginning I tough the same, but in one side there is the power
socket, so isn't practical to have the board on top of that, and in the other side
I have those big orange caps, and no spacer big enough so I ended gluing the
2 boards together (and soldering the the 2 ground planes at the back).
I saw you posted the picture of my modular in your Hall of Fame, thank you
very much, I'm very glad to be there.
Is not the best shot tough, when I had the time I will try to get a better picture.
Or may be I wait until the cabinet is completed.
Sebo
My Music:
Niio1
