Audio files: 172
Posted: Thu Nov 04, 2010 12:15 pm Post subject:
That's beautiful. How does it sound? _________________ Garret: It's so retro.
Parker: Like, old and outdated. Home,My Studio,and another view
Joined: Dec 26, 2006 Posts: 144 Location: United Kingdom
Posted: Fri Nov 05, 2010 10:37 am Post subject:
Just finished a few 'Noisemakers' as a present for my ward Ollie - it was his 10th birthday, and the family were only in the UK for a few days. I had zero debug time, so I missed a minor assembly fault on the PIC synth's display. I'll sort it when I see them at Christmas - it works fine. The controls on the PIC synth are miniature sealed cermets, with integral knob. I got a batch virtually free in some scrap, (they cost over £5 each in normal quantities), otherwise I'd have gone for Alpha pots and ReAn knobs. The box is transparent red, so I just put a window in the panel overlay to let the display show through. Ollie had a hand in the panel design for the Cacaphonator, He wanted handles like my WSG, fortunately I found some old ones just the right size in the scrap box.
Filesize:
387.99 KB
Viewed:
319 Time(s)
Filesize:
443.64 KB
Viewed:
301 Time(s)
Posted: Sat Nov 06, 2010 9:05 am Post subject:
loydb wrote:
I bet he really likes that, nice build.
Thanks: I think my next project for him may have to be a mixer, with a headphone output - his mum and sister are getting a bit of an ear-bashing at the moment.
I'm hoping to get an external audio interface to work on his net book, then he can do some recording. _________________ Mike
working on my backlog: after almost one year after i had this geat circuit on my breadboard the first time, i finally finished my dual thomas henry X-4046 VCO module.
Joined: Aug 10, 2008 Posts: 270 Location: Salt Lake City, UT USA
Posted: Thu Nov 11, 2010 2:07 am Post subject:
Start of my Synthasystem!
Thought I'd share these here, too. My Steiner Synthasystem resurrection is well under way. VCO, VCF, and Triple EG pictured here. I don't have a photo of the VCA. Also tested, Sequencer, Peak Selector, and Frequency Divider. I've got prototypes for a VC Trigger Generator, and Sample & Hold on order.
Triple EG
Filesize:
256.03 KB
Viewed:
155 Time(s)
Triple EG backside
Filesize:
265.7 KB
Viewed:
159 Time(s)
VCO
Filesize:
237.13 KB
Viewed:
150 Time(s)
VCF
Filesize:
485.83 KB
Viewed:
157 Time(s)
VCF backside
Filesize:
250.06 KB
Viewed:
155 Time(s)
_________________ David M. Ingebretsen, M.S., M.E.
Posted: Mon Nov 15, 2010 3:45 am Post subject:
Thank you! Yes, made a board to mount switches and LEDs. It was easier that way... The pots are still hole mounted though. But that way I didn't have to have the ugly nut on the front panel. And just the pot shaft goes through the panel. _________________ http://www.thehumancomparator.net/
Joined: May 16, 2005 Posts: 8933 Location: Birmingham, England, UK
Posted: Mon Nov 22, 2010 3:52 pm Post subject:
loydb wrote:
Finally completed my MFOS combo mini-controller and v/oct calibrator. Padauk, bloodwood and ebony carcase with a custom MFOS glass marble as a knob. For the full build blog, see my sig below.
Oh man! That's a thing of beauty! I sincerely apologise to Ray for not liking the design in the first place- as this has clearly proved me wrong! _________________ ACHTUNG!
Are there any more details avaible on the sandwich construction? I wonder why you didn't need a fancy interface for deglitching like Scott Stites' ribbon controller?
Ian
I did some de-glitching. I skipped the ground-pin on the hotpots and put a 10K ohm resistor between signal and ground instead. Not a fancy solution, but working great.
The sandwich is like this:
Front:
Middle:
Back:
I have some pictures of the construction, but I think you get the point from the screen-dumps above.
