  Faux Pas Quartet and friends Music From Last Thursday [rebroadcast]
Voltage Controlled OpAmp RingMod (Modulator)
Page 9 of 9 [209 Posts]
Goto page: Previous 1, 2, 3, ..., 7, 8, 9
jumunius
PostPosted: Tue Mar 08, 2011 2:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are the trimpots best as multi-turn or single? I don't see it specified, but the graphics on the PCB look like multi-turn. (Unfortunately the single turn trimpots I ordered face into other components making them pretty useless!)
(I have the same question about the PS3100 which I received today thanks very much!)
Jim
PostPosted: Tue Mar 08, 2011 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
it is meant to be multiturn, however for my SMT version i used single turn, which works well, too. you just need a calm hand Very Happy
see above. and the trims on the PS3100 are not critical anyways (IMHO)
fonitronik at
jumunius
PostPosted: Tue Mar 08, 2011 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, thanks. Good to know.
wmonk
Audio files: 12
PostPosted: Sun Aug 14, 2011 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Finished one last week. I absolutely love it! Very Happy
Sounds will follow Smile
Woody
Weblog!
Kits for synthesiser modules in Europe
PostPosted: Mon Aug 15, 2011 3:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Sounds will follow
your wooden panels look awesome, woody.
i am looking forward to hear it!
fonitronik at
PostPosted: Mon Oct 24, 2011 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
BTW this module will be available as professional built/assembled complete eurorack module soon:
fonitronik mh31
fonitronik at
jumunius
PostPosted: Sat Dec 10, 2011 12:59 pm    Post subject: Re: Powered up the VC RingMod last night Reply with quote  Mark this post and the followings unread
fonik wrote:
kkissinger wrote:
Both VCA's work ok. The Carrier signal is ok. The Modulator signal is clipped though ... so, I have some troubleshooting to do.
does it clip at the testpiont TP2, or does it clip at the output? latter would be the feature, not a bug.
Hi, I'm finally getting around to trying out this module more thoroughly and I'm having problems including the fact that it seems a little TOO distorted. If I use a triangle wave into either the mod or carrier, the waveform at the related test points looks a little sinusoidal. Not completely, just like a triangle with more curve. What could be causing this?
(Adjusting the trimmers seems to affect the waveform but the result never seems to be a proper triangle.... and anyways, I assume the trimmers are merely supposed to adjust DC offset, no?)
-Jim
PostPosted: Sat Dec 10, 2011 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
you never will get out what you put in Twisted Evil
i tried it with a triangle, and i never got it perfect at the TP's. the VCA'a are stripped down.
anyways, unlike other ringmods you could not use this modulator as a VCA. it is a weird voltage mangler in the end...
fonitronik at
jumunius
PostPosted: Sat Dec 10, 2011 5:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, ok, well, good to know. A little mangling always comes in handy. Good to know to expect it! Smile
-Jim
AmbiphonicDSP
